06-15-2018, 09:22 | #32 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft CPU: GenuineIntel Platform: Windows NT 6.2 (Build 9200 ) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files (x86) C:\Program Files (x86)\Common Files C:\Program Files (x86)\Nokia\Phoenix\ C:\Users\Paul Enukoha\Desktop C:\Users\Paul Enukoha\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Can't open internet URL. InternetOpenURL failed! App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 70193 Serial: 98214 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98214 HID: CE6AC7A04160007D, HWK: A1.04-PRO1 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Something Wrong, Try to Use [Update Box] Box: 1 Location: 70193 Serial: 98214 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98214 HID: CE6AC7A04160007D, HWK: A1.04-PRO1 LIC: True REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 98214 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 98214 LIC5: True BOXK: 2 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98214 HID: CE6AC7A04160007D, HWK: A1.04-PRO1 LIC: True Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
06-19-2018, 12:32 | #33 (permalink) | |
Major Poster Join Date: Sep 2017 Location: SriLanka
Member: 2754910 Status: Offline Thanks Meter: 76 | Quote:
Dear 1st of all install the (UFSx_Support_Suite_Setup_v02.03.00.07.exe) from your downloaded folder. Then Open (UFS_PANEL_2708.exe) also from your downloaded folder. Do not Open the UFS_PANEL or UFS Suit from which your installation or installed. Report Post | |
06-19-2018, 12:33 | #34 (permalink) |
Member: 2754910 Status: Offline Thanks Meter: 76 | Dear 1st of all install the (UFSx_Support_Suite_Setup_v02.03.00.07.exe) from your downloaded folder. Then Open (UFS_PANEL_2708.exe) also from your downloaded folder. Do not Open the UFS_PANEL or UFS Suit from which your installation or installed. Report Post |
06-19-2018, 12:42 | #35 (permalink) |
Member: 2754910 Status: Offline Thanks Meter: 76 | even If you guys do not understand how to install and use it, kndly follow this Post Here and Download the fully pack from this Link Download here and follow the post above |
06-20-2018, 15:09 | #41 (permalink) |
Member: 2754910 Status: Offline Thanks Meter: 76 | Download file attachments and then unzip and move the files to this path https://www.gem-flash.com/vb/attachm...4&d=1443629289 C: \ Program Files \ Nokia \ Phoenix \ FLASH and Vagif replacement If requested then open the update interface and press CHECK BOX and then CHECK SERVER and then INSTALL and then close the update interface Last edited by UniverCellSoft; 06-20-2018 at 15:18. |
