Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-16-2019, 22:10 | #61 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
http://forum.gsmhosting.com/vbb/f317...l#post13554162 b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
08-30-2021, 17:56 | #62 (permalink) | |
Junior Member Join Date: Apr 2018
Member: 2832230 Status: Offline Thanks Meter: 2 | Quote:
08-30-2021, 20:22 | #63 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Read this whole thread from beginning. Also read WHOLE thread : https://forum.gsmhosting.com/vbb/f31...eeded-2140512/ b.r. Alex
10-21-2021, 16:38 | #64 (permalink) |
Junior Member Join Date: Oct 2021 Location: Italy Age: 37
Member: 2999120 Status: Offline Thanks Meter: 1 | First of all, thanks Brka. Really, thanks! We are a small italian startup and right now we have about 15 Pixi 4 4034x 2AALGBA-1 and we were not able to find 1) the stock rom 2) a custom recovery in order to install our APP backup for our small business purposes. we tried really lots lots of Stock Rom 4034x and similar, but finally i've ended up in the #46 post of the other thread and we were able at least to find the original stock rom for our smartphone ^^ so 1) is solved! for 2) do any of you know a custom recovery for this model? cause we tried at least 12 recovery Pixi 4 4034 but none seems to work. Really thanks! |
The Following User Says Thank You to elfigus For This Useful Post: |
10-21-2021, 17:08 | #65 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | @elfigus These are all custom recoveries i could find : DOWNLOAD patiently try them one by one, some of them should work. i lost track about that model ... what version of android is inside ? p.s. There is also this TWRP recovery porting utility, but it works for android 5, 6, 7, 8.0, 8.1 & 8.1go. p.s.2 If bootloader is locked - patched boot also need to be flashed (utility will make one for you) (patched boot circumvent some security checks in bootchain, so custom recovery can be started) p.s.3 You dont have to flash recovery, if able to enter fastboot - you can just BOOT it, do the rooting job, so modified recovery wont stay permanently (and cause bootloop) p.s.4 You can try with MAGISK too, and from developer options - enabled "OEM Unlock" try it and post results .... b.r. Alex credit for TWRP porter : Hovatek forums
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 10-21-2021 at 20:57. Reason: added more info |
10-22-2021, 12:20 | #66 (permalink) | |||
Member: 2999120 Status: Offline Thanks Meter: 1 | Quote:
I'll try also your utility TWRP and I see what I am able to do. Thanks in advance, and obv if we are able to solve this problem you well deserve a donation ^^ ***EDIT: ok, i've used your TWRP tool and it was super easy, super fast, and super effective! in 30 sec I've created a TWRP recovery and with SP flash tool it's now on the Pixi 4 and it it working ***EDIT: I let the backup in the office but on monday I will try to restore it with SD card in the recovery and it should be ok! ok, so I didn't remember that the backup we used for the other Pixi 4 99% will not work with this version cause after the restore from SD it will push the data etc file of the other Pixi 4 which has a different Stock ROM so I tried to install the Cyano13 or Lineage13 into this Pixi 4 through the TWRP recovery I go to install I select the zip Cyano 13 or Lineage13 and It keep giving me an error , i'll attach the photo as soon as the forum let me manage attachments ^^ any tips? Last edited by Brka; 10-22-2021 at 21:30. Reason: merged posts | |||
10-22-2021, 21:28 | #67 (permalink) | |
however - more resources (custom ROMs) - HERE (use translate in chrome) mediafire somehow didnt accept files ... anyway, it's easy to make twrp with that porting utility b.r. Alex
10-23-2021, 14:12 | #69 (permalink) |
Member: 2999120 Status: Offline Thanks Meter: 1 | Ok, so before installing any custom rom, if from TWRP recovery i do Wipe data, system, cache I was able to install a few custom ROM like cyano13 and lineage os 14 and other without any red error using install and then selecting the zip custom rom file but when i reboot the system after the installation, the smartphone stays stuck in the Alcatel logo boot So I tried to flash the boot file from the original ROM, and when I do that, the smartphone stays stuck not in the Alcatel logo but now in the logo of the custom ROM like cyano etc but neither way the smartphone is not able to start any suggestions? I cannot register in the russian forum cause during the registration format i have to answer to a math question reading an image and i am not able to translate it ahah |
10-23-2021, 14:30 | #70 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If memory serves me, Correct procedure is: - install/boot twrp - from twrp, format data - from twrp, wipe system, cache, dalvik - reboot twrp from twrp (reboot to recovery) - sideload/install from sdcard desired rom - reboot to system Should boot normally, after, if needed, reboot to twrp and install gapps Magic step is to format userdata from twrp, Then reboot twrp from twrp, so new filesystem will take effect B.r. Alex
10-25-2021, 20:03 | #71 (permalink) | |
Tomorrow we will start to create the new backup using the boot rooted with magisk and we see from there! thanks anyway | |
11-04-2021, 08:12 | #72 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | 4034X-2ARGCH1 firmware need after reset phone hanging on logo, tried with some other file still same, please share the if anyone have thank you |
11-04-2021, 16:28 | #74 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | You can flash with any flash file. i had a phone with same pid, and normally flashed it to other european retail pid. problem you had was of "other nature". b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
