Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
04-20-2008, 07:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | I'm really confused about this L6 LCD problem !!! I have searched here & in other forums too & found some solutions for such similar problem; some to reflow the display IC & some said it's software problem & that i have to flash it with certain flash file & have already did flashed it with it also have reflowed display IC but all with no solve it. Till now i havn't tried another LCD cause i don't have one already, but i don't think it could be LCD fault at all due what i have mentioned above. What it can be ???!!! |
The Following User Says Thank You to mobilagy For This Useful Post: |
05-08-2008, 09:35 | #3 (permalink) |
Major Poster Join Date: Mar 2006 Location: metta quaters
Member: 241277 Status: Offline Thanks Meter: 4 | do ur best chang lcd first i had a similar pb ,and i change lcd ,it work for few days and started back ,i had to flash phone with smart moto and everything was ok.good luck and courage |
05-08-2008, 14:39 | #4 (permalink) |
Junior Member Join Date: May 2008
Member: 767885 Status: Offline Thanks Meter: 0 | I was haaving the same problem. Two times I sent it to Service Centre & at the end I changed it. No Luck!! __________________________________________________ search engine optimization |
06-30-2008, 17:25 | #5 (permalink) | |
Banned Join Date: Jun 2004 Location: GSM HEAVEN Age: 36
Member: 69984 Status: Offline Thanks Meter: 170 | Please try this solution. Quote:
Brother see the attachment Remove the cover wich is mentioned in picture.this is the camera and display processor under the cover.after removing cover check the phone display if no response 1st:heat the ic 2nd:reball the ic 3rd:change the ic when I have this problem i only removed the cover and phone display was ok | |
Confuse! Confuse! About T156 new sec! Please do something | memobiles | FuriousGold | 5 | 11-15-2009 11:45 |
im confused and I'm really disappointed | rachelyna | Universalbox | 1 | 03-18-2009 08:43 |
Pls help me, I'm really confused about cruiser 11 | Diablo81 | Cruiser Suite | 3 | 05-31-2007 21:09 |
Anyone know about this sharp 802 problem | JammerTwo | Cruiser Suite | 8 | 01-14-2007 20:02 |
Really confused about this error Error 11:FFFF8200 with griffin | chafeh | Griffin | 1 | 06-27-2004 17:56 |
