Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
10-30-2008, 16:13 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 883077 Status: Offline Thanks Meter: 2 | Moto rokr E6 flashing problem...plz help.... I tried reinstalling the drivers and with 6 diffrent firmware files but in the end it shows flash failed with following log file ERROR: Interface BP: Error erasing subscriber unit. Device API Error: 0xE0020083 Command: ERASE File: Y:\test_dev_usb\flash\code\flashdll\PST_FP_FlashTh read.cpp Device ID: 0 ERROR: Phone[0000]: Flash failed. File: Y:\test_dev_usb\flash\code\flashdll\PST_FP_FlashTh read.cpp Device ID: 0 ERROR: Flash failure: Interface BP: Error erasing subscriber unit. Device API Error: 0xE0020083 Command: ERASE (Error Code: e0020083), Detailed Error Details: Direction of the Error=2000, Command Value=100000, Code Group Number=No Codegroup File: Y:\test_dev_usb\flash\code\flashdll\FlashHdlr.cpp Device ID: 0 ERROR: Error getting subscriber unit information. File: Y:\test_dev_usb\flash\code\flashdll\PST_FP_FlashTh read.cpp\ I tried with different other version of RSD lite but it is giving the same error again.Could you please suggest what`s wrong going on....??? |
11-19-2008, 09:30 | #3 (permalink) |
Junior Member Join Date: Nov 2008 Location: Islamabad Pakistan Age: 43
Member: 899527 Status: Offline Sonork: [email protected] Thanks Meter: 0 | use a new version of rsd lite for upgrade sw,also check all hard keys or not shorted especially camera key and other sside keys.if still fails its means ics like processor and flash are liquid damgae under shields.then remove the shields with hot gun at a valid temprature= and clean the ics with some good cleaner. |
e700 flash problem ... plz help ! | TRABEL | Twisterflasher | 0 | 07-21-2005 16:33 |
samsung e710 MAJOR FLASHING PROBLEM PLZ HELP!! | foneman111 | Trident/AGERE Platform | 5 | 01-30-2005 00:38 |
