Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
10-04-2007, 14:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | ..::V3 any charging problem solve here::.. i tested this solution with 3mobiles all success |
The Following User Says Thank You to sree krishna For This Useful Post: |
10-04-2007, 22:52 | #5 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | Very Nice Krishna, Thnks For Hsarimh Here Nanaba... As Im Having Doubt Here ...wth This Tips,can I Solve Invalid Battery Probzzz N V3?? Good Luck,xpecting More From U. Keep Going |
10-26-2007, 13:06 | #15 (permalink) |
Junior Member Join Date: Aug 2007
Member: 576052 Status: Offline Thanks Meter: 0 | Hi, my phone is V3 normal i've tried it. but i've got a problem: - It's ok when i use usb port in my computer. - when i plug the charger: The voltage in V-Batt is 4.3V (normal = 3.9) --> the charge way is good. But it doesn't change the style to Loud Style, and the display charging icon is not worked. That means i can not realize my phone is charging or not when using Charger. Please help me. thanks |
c 115 / 117 charging problem solve 100% work. | maheshsaiganesh | Motorola Hardware Repair | 22 | 02-11-2011 11:17 |
3110 not charging problem solved by sd repair thanks mxkey | SanjanMobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-16-2010 16:55 |
W220 charging problem solved | gsm9l | Motorola Hardware Repair | 25 | 01-19-2010 15:18 |
Nokia 1208 1200 listen beef display show not charging Problem solve | madni shah | Nokia Hardware & Hardware Repair | 1 | 12-31-2009 20:31 |
W850 Charging Problem Solve? | Kanwalgee | Sony Ericsson Hardware Repair | 1 | 06-16-2008 17:19 |
