10-21-2007, 17:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: London/ Slovenia/ Mauritius
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | N95 unlock but its 10/10 what next? I have encountered this problem before and managed to solve it Lets just say I have been searching the internet/forums for the past couple days without any luck. But im stuck as i tried to sort it out, but its 10/10 still Any suggestions to what I can do ? Code: ]Phone is in: Unknown mode Model: RM-159 (Aalto (EU) ) V 06wk41v23.4/17-04-07/RM-159 (c) Nokia Production serial number SGI764852 Product code 0547869 Module code Basic production code 0537959 Flash code Order number Long production SN 0 MCU SW V 06wk41v23.4/17-04-07/RM-159/(c) Nokia HW 5900 PCI RFIC 17141714 Retu 15 Tahvo 22 IMEI: 356996014449069 WARNING: VPP pin is not connected, disabling VPP. IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 PMM Send File Sending SIMLOCK record... Operation Completed V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996014449069 busy, waiting... e/311/Authorization limit exceeded in current period; Server error Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996014449069 busy, waiting... e/311/Authorization limit exceeded in current period; Server error Thanks in advance for any help |
10-21-2007, 17:57 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | then u need RPL i think... key bus count is 0/3 then u can try with someother tool...for unlocking if u feel RPL is costly... |
10-21-2007, 18:23 | #3 (permalink) |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | Here we go i let the SX4 settle for 20 minutes or so.. I tried and I get this Code: Connect... Login... IMEI: 356996014449069 busy, waiting... Connect... Login... busy, waiting... PMM Authorize FAILED So im a bit lost now. I managed to do 5 handsets that had 10/10 before, I am not sure whats so different about this one |
10-21-2007, 18:29 | #4 (permalink) |
Super Moderator Join Date: Feb 2005 Location: United Arab Emirates , Dubai Age: 38
Member: 113928 Status: Offline Sonork: 100.111866 Thanks Meter: 1,838 | Write pm backup search n C:\Program Files\GriffinTeam\MT-Box\bb5bckup if u make pm backup before unlock if u dont have must u need rpl to Counters 0/10, 0/3 |
10-21-2007, 19:16 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
10-21-2007, 19:23 | #6 (permalink) |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | i have written the backup several times Code: Sending SIMLOCK record... Operation Completed V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 |
10-21-2007, 19:30 | #7 (permalink) | |
When you write field 308 you should receive a warning then you must choose Yes instead of No. Good luck !!! | |
10-21-2007, 21:04 | #8 (permalink) |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | yup received warning several times I click yes But it says use sx4 to authorize and fails or something like that. I guess only way is rpl |
10-21-2007, 21:32 | #10 (permalink) | |
10-21-2007, 23:12 | #11 (permalink) | |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | Quote:
OK SNSOFTKILLER thanks for your help. I have downloaded the file and will do as the video tutorial says Thanks for your time Best regards DJ | |
10-21-2007, 23:33 | #12 (permalink) |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | ok well here is my last attempt at this. I saw the video, not that i didnt try what it suggested Here we go Check this out Code: Phone is in: Local mode Scanning files, please wait... Done Model: RM-159 (Aalto (EU) ) V 06wk41v23.4/17-04-07/RM-159 (c) Nokia Production serial number SGI764852 Product code 0547869 Module code Basic production code 0537959 Flash code Order number Long production SN 0 MCU SW V 06wk41v23.4/17-04-07/RM-159/(c) Nokia HW 5900 PCI RFIC 17141714 DSP dsprap_pb06w41v24 Retu 15 Tahvo 22 IMEI: 356996014449069 WARNING: VPP pin is not connected, disabling VPP. PMM Send File Sending SIMLOCK record... Operation Completed V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996014449069 busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 PMM Send File Sending SIMLOCK record... Operation Completed V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 Sending to phone Resource:134 Sending SIMLOCK record... V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996014449069 busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 356996014449069 Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 but checking simlock status, still 10/10 |
10-22-2007, 00:27 | #14 (permalink) |
Member: 5360 Status: Offline Sonork: 1577169 Thanks Meter: 24 | well my result was its still 10/10 I get the impression there is a bug in the MT software ? forgive me if im wrong. But I have a friend with a similar situation as me. But he wrote the pm with JAF which did reset the counters. Trouble is, my JAF is under construction (its broken) DJ |
10-22-2007, 01:12 | #15 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: UK
Member: 231072 Status: Offline Thanks Meter: 16 | Quote:
i had same problem, i used cable with tx2 line and it sorted my problem. | |
N95 unlocked but still locked | GSM SNIPER | BB5KING | 4 | 01-20-2009 22:40 |
N95 when unlocking but testpoint failed.. but ok i have the pm what next ? | DjSwift | MT-BOX | 1 | 04-08-2008 21:46 |
N95 - 10/10 but 0/3 ! | i_seeque | J.A.F. V-SPEC | 3 | 12-20-2007 21:09 |
What next if i change uem and its two flash ics? | N761 | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 07-21-2007 20:13 |
