04-17-2007, 20:12 | #48 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | I will be very happy if you can add Sirocco flash files selection. I know that it's not so difficult but having a mistake in so expensive phone... Unlocking was too easy BR Luskao |
04-26-2007, 07:09 | #50 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Ukraine Age: 44
Member: 7575 Status: Offline Thanks Meter: 12 | Bug! After I close PKD-1 emulation the box resets it's state to normal box mode, but phones cann't be booted or readed (100% error with 1600, other don't know). Reinitialize box button don't help, only disconnect\connect box. |
04-26-2007, 07:33 | #51 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: NA & CN
Member: 99013 Status: Offline Thanks Meter: 52 | Quote:
Didnot try 8800d ,to expensive for me! ,Seems flashfile selection for 3100b and 8390 and nokia E62 not working properly either.Pls correct it ... Gsmdoctorca | |
04-26-2007, 16:53 | #60 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | please see this MTB_NK1_30beta Phone is in: Local mode Model: RH-51 ( 7610) V 2004_wk21v3/20-05-04/RH-51 (c) Nokia. Production serial number DDE722549 Product code 0514521 Module code 0202215 Basic production code 0511637 Flash code Order number 7878787 Long production SN MCU SW V 4.0421.4/22-05-04/RH-51/(c)NMP HW 6003 PCI UEM 32 UPP 4225 RFIC 0204 DSP CN3.50 PPM V 4.0421.4/22-05-04/RH-51/(c)NMP.33 BT MCM IMEI: 35338800015xxxx VPP is DISABLED. Phone is in: Local mode IMEI: 35338800015xxxx Generated RPL file from resource 208 C:\My Documents\RH-51_35338800015xxxx.rpl Processing File: RH51_52_67_68PE706420.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia 84545A54643361AF8427DA0359F1 Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 22F8 0000 0011, 10 04000000: Samsung, 00EC 22FA 0000 0011, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[24.69 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 00FFFFFF] erasing region [02000000 to 0287FFFF] erasing region [02FC0000 to 02FEFFFF] in 200.78s Flash[24.51 MB]...in 169.80s * * Processed file in 387.24 seconds Processing File: RH51PE706420.03 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia 845AC5CDF6B77AD8C9A4CF8C6662 Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 22F8 0000 0011, 10 04000000: Samsung, 00EC 22FA 0000 0011, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[2.75 MB]... erasing region [00000000 to 0000FFFF] erasing region [02A00000 to 02CAFFFF] in 21.78s Flash[2.73 MB]...in 19.94s * * Processed file in 57.99 seconds * * * Phone flashing done in 7:27 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 2006_wk41/11-10-06/RH-51 (c) Nokia. IMEI: 3533880001xxxx Factory Default Settings...OK PMM Send File Operation Completed Phone is in: Local mode Imei: 353388000152589 SIM Unlock FAILED mtb_nk_1_29_5.exe Phone is in: Local mode Model: RH-51 ( 7610) V 2006_wk41/11-10-06/RH-51 (c) Nokia. Production serial number DDE793814 Product code 0516453 Module code 0202215 Basic production code 0511637 Flash code Order number 1234567 Long production SN HW 6003 PCI UEM 32 UPP 4225 IMEI: 35338800015xxxx Phone is in: Local mode Imei: 35338800015xxxx SIM Unlock Successfull |
Bug reports, Test Reports, Suggestions and Comments all welcome here | NFF Box Team | Nokia Fault Finder Box | 40 | 09-05-2008 14:20 |
N95 Flashing Problem With Mt_box V1.30Beta | ccw123 | MT-BOX | 9 | 05-02-2007 13:09 |
MTB_NK 1.29 Bugs Report Here and commen are welcome | MicrostarGSM® | MT-BOX | 68 | 01-29-2007 16:12 |
MTB_NK v1.25 bugs and reports post here | MicrostarGSM® | MT-BOX | 24 | 11-23-2006 07:51 |
Comments, Suggestions, Bug Reports, Criticsm | Infinity-Box | Infinity-Box | 25 | 05-14-2005 18:07 |
