08-10-2007, 13:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | what this problem Connect... Login... IMEI: 35663400376xxxx busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 35663400376xxxx busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 35663400376xxxx busy, waiting... e/640/command execution error; Server error Phone is in: Local mode Model: RM-42 (N90) V 05wk07v34.3/16-02-06/RM-42 (c) Nokia. Production serial number SQB415369 Product code 0523871 Module code Basic production code 0522176 Flash code Order number Long production SN MCU SW V 05wk07v34.3/16-02-06/RM-42/(c) Nokia. HW 1100 PCI RFIC 150a160f DSP gromit_05wk07v24 LCD 2724629 APE SW Core V 5.0607.7.3/16-02-06/RM-42/(C)Nokia APE Variant V 5.0607.7.3-Euro2/16-02-06/RM-42/(C)NOKIA. Retu 32 Tahvo 52 APE HW 256 APE ADSP SW 16053 IMEI: 35663400376xxxx WARNING: VPP pin is not connected, disabling VPP. |
08-10-2007, 14:22 | #3 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | @911GT! Same problem to me with all account which has I credit Phone Info: ========= Phone is in: Local mode Model: RM-92 (N80) V 05wk33v33.1/22-06-06/RM-92 (c) Nokia. Production serial number Product code Module code Basic production code Flash code Order number Long production SN MCU SW V 05wk33v33.1/22-06-06/RM-92/(c) Nokia. PCI RFIC 17191719 DSP miro_05wk32v37b APE SW Core V 4.0623.0.41/26-07-2006/RM-92/ APE Variant V 4.0623.0.41-31.04/26-07-2006/RM-92/ Retu 14 Tahvo 21 APE HW 1 APE ADSP SW 256 Camera 1 APE BT HCI Version 2 (rev. 0). LMP Version 2 (rev. 3504). Manufacturer 13. IMEI: 3583610XXXXXXXX ================================================== ======= SX4 info: ====== Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... e/640/command execution error; Server error Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... SuperDongle Authorization Procedure failed! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 3583610XXXXXXXX busy, waiting... e/640/command execution error; Server error ================================================== ====== Sim Lock State =========== V 05wk33v33.1/22-06-06/RM-92 (c) Nokia. IMEI: 3583610XXXXXXXX Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F Counters 0/10, 0/3 |
08-10-2007, 15:02 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | you never can authorize this phone!!!!! you have a bad simlock data!!!!! if dont have a backup of simlock need to make RPL file to restore it! dot try anymore before restore simlock data only do slowly server for these who real needed. if you try to unlock this phone before simlock data damged then you have a 134 filed backup, restore it and check simlock data. Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F this is incorrect FFFFFFFFFFFFFFFFF!! |
08-10-2007, 16:37 | #5 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | @911GT! I flash my phone software version 1.35 phone goes IMEI 1234???? I erased flash and write Backup IMEI phone IMEI is OK . Now I write back up pm using with “SX4” option. any solution or only now ask to rpl solution. |
08-13-2007, 07:43 | #6 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | here mate my log V 05wk07v34.3/16-02-06/RM-42 (c) Nokia. IMEI: 35663400376xxxx Operator: 0000000000000000 Profile bits: 2440700000000000 Sim Status: Not locked if ı make new ask phone repaired ? can it connect SX4 ? Phone shut down automatic problem only 308 ı think bad data... |
08-13-2007, 13:55 | #8 (permalink) | |
Member: 409197 Status: Offline Thanks Meter: 75 | Quote:
restart phone and check simlock state. if you have a PM backup and simlock again is bad after 134 field then need to flash phone on a version who is when you make a PM Backup and then to restore 134 then you will have a good simlock state. if not then the way is only one ASK2RPL | |
whats this problem ?? pls see this...[ANSWERED & SOLVED] | T-mobile | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 12 | 03-14-2010 19:41 |
Whats This Problem Again!!! | freeman2001 | SCDR II | 3 | 05-29-2008 23:45 |
Whats This Problem? | ..::khaled::.. | Cruiser Suite | 4 | 05-16-2008 15:24 |
whats this problem in dct-4 and same in bb5 | imran tec | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 11-23-2007 02:57 |
Whats this Problem Motorola C261 ... | JammerTwo | Infinity-Box | 1 | 09-05-2007 07:53 |
