x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-20-2002, 08:37 | #2 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Macedonia Age: 43
Member: 10742 Status: Offline Thanks Meter: 13 | hi firmware your mob. with v18..then use repair bin.for v18 and use workshop 1.22..put reair bin in workshop and press on eeprom..then start write flash.....YOUR BATTERY MUST BE FULL |
04-20-2002, 13:41 | #3 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Don't use Mr Zee on version 24, it will kill your phone ! Only with logs ! If you want to upgrade your phone to ver 24 and your phone was unlocked with partial, then flash phone with version 21, phone gets locked back, unlock with Mr Zee software then you can upgrade your phone ! |
04-21-2002, 08:56 | #4 (permalink) |
Freak Poster Join Date: Nov 2001 Location: BY Age: 51
Member: 7101 Status: Offline Thanks Meter: 0 | The main problem now: I can't write EEPROM to my phone by any program! any ideas... as I wrote before, I tried all this programs: X35ee_uploader , Martech 1.7 Koci 5.30 Ziemens x3x Series Workshop 1.22 by Pro @cale I made it before for hundred times, but now eeprom writes only 90-95% and stops |
04-25-2002, 05:01 | #5 (permalink) |
Insane Poster Join Date: Apr 2002
Member: 10746 Status: Offline Thanks Meter: 0 | 1. USE MARTECH 1.7 TO KILL YOU PHONE (WRITE FULL FLASH (CHOOSE ANY C35 IN MARTECH DIRECTORY TO WRITE), WHEN REACHED THE POINT THAT START WRITING (AFTER ERASED) JUST UNPLUG THE PHONE CABLE 2. FLASH YOUR PHONE WITH WINSWUP VER 21 3. USE ZIEMENS 1.22 TO WRITE ONLY EEPROM FROM REPAIR_BIN AFTER EEPROM CLICK CEE_REPAIR, YOU GET WORKING PHONE AGAIN 4. USE IMEI CHANGER BY LAED TO CHANGE IMEI BACK & UNLOCK 5. FLASH YOU PHONE TO VER 24, YOU GET WORKING PHONE WITH VER 24 BUT YOU CANN'T USE LEAD SOFTWARE TO CHANGE IMEI ANYMORE, IT WILL KILL THE PHONE, LEAD CAN GO UPTO VER 21 ONLY THIS SOLUTION TESTED ON C35i AND WORKS 100% Last edited by ka46; 04-25-2002 at 05:14. |
05-01-2002, 10:52 | #6 (permalink) |
Major Poster Join Date: Apr 2002 Location: Indonesia Age: 46
Member: 11444 Status: Offline Thanks Meter: 0 | Need Solusion my s35 upgrade to v2404 but i cant change imei if i change my phone just blink and i fix again with x3x pro is ok. anyone have imei changer support v24 ?? or any idea ? |
05-02-2002, 00:12 | #7 (permalink) | |
Guest
Posts: n/a
Member: | Re: Need Solusion Quote:
05-07-2002, 16:11 | #10 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | This v4.02 logger looks like v3.00 but only e-mail is modified. Boot and flash loaders are the same. Size of the 4.02 and 3.00 are the same. So what else... |
Dead U8330 after upgrading to v20a | mihaser | LG | 5 | 05-23-2006 13:43 |
C35 v18 dead after upgrade to v24 | gama_cell99 | x1x to x45/x50 | 2 | 04-17-2005 16:42 |
Totally dead S55 after upgrade! | sylcon | E-Gold Based Phones | 7 | 12-09-2003 19:34 |
Dead C35 after flashing..Please help me! | gsmsoft | x1x to x45/x50 | 2 | 11-20-2001 01:51 |
C35 dead after upgrade an downgrade | the_viper | x1x to x45/x50 | 6 | 03-24-2001 11:49 |
