x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
08-29-2002, 20:55 | #63 (permalink) |
Insane Poster Join Date: Apr 2002 Location: INDONESIA Age: 61
Member: 10843 Status: Offline Thanks Meter: 0 | Hi Bedjo, 2118 still need dongle, couse no free soft for c45 map maker. (because 2118 need C45 MAP Files NOT SL454 MAP Files, but we need Phone model SL45 for write imei.) C45ba20 still need dongle, couse no free soft for c45 map maker. B.R Hendut |
09-04-2002, 08:19 | #65 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | Hello to all I have problem with my C45. its dead with BA20 . I readed old posts i tried to flash it with All3/4 2.0.5 xXz , Xak is not working for me because i dont have Win 98 Se instaled. I cant get my phone working (wrong soft) Just beep . Can anyone send me tested flash for it ? thanx in advance Pali |
09-05-2002, 10:12 | #68 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | I've flashed it with All 2.0.5 XxZ, then Winswup Flash 31. then unlock with C45_MT50 unlocker. then it was WRONG SOFT. I read log , Winner58 calculate map for me, in log request section. But he send it to forum not via email. when i copy it to file and open with Logger 4.02 it writes me ERROR IN MAP FILE ( any idea ? PAli |
09-05-2002, 10:21 | #69 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Serbia
Member: 9165 Status: Offline Thanks Meter: 0 | Quote:
each line "blank" space, like this: 238479284982048_ (this is blank) must be like this: 238479284982048 | |
09-05-2002, 10:52 | #71 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Yogyakarta Indonesia Age: 55
Member: 12547 Status: Offline Thanks Meter: 0 | Hi Pali... For C45 BA20 the tricks for IMEI WRITER is very unique.. After u open u r map file from winner58 in u r logger for write imei u can change type to SL45 first and than klik write imei my friend... Try that... it's 100% works for BA20 I try by myself..... Sorry for my bad english..... B.R Eriko |
09-05-2002, 10:55 | #72 (permalink) |
Member: 12547 Status: Offline Thanks Meter: 0 | Hi Pali... U r phone must be on position "Wrong Software" OK? If u r phone not wrong software this tricks not work... Thanks B.R and not B.T he he he Eriko |
09-05-2002, 11:01 | #73 (permalink) |
Member: 12547 Status: Offline Thanks Meter: 0 | Hi Pali... For copy map file from winner58 try to open another map file and block all text from winner58 and than copy all to the old map... Don't make a new space... If u want to paste to another map try block all from the old map and paste with the new map.... Try again with another map don't try with the same old map OK? I have same problem a few days ago... I can solved that.... Thanks B.R Eriko |
09-05-2002, 15:17 | #74 (permalink) |
Freak Poster Join Date: May 2001 Location: Indian Ocean Age: 54
Member: 4765 Status: Offline Thanks Meter: 0 | Delete space after each * ******************** Section ********************HERE ***************** ID: DF254789 ****************** ********** Old IMEI = ??????-??-?????? ********** ********** New IMEI = 099999-00-123456 ********** ************************************************* DELETE THIS EMPTY LINE IMEI Block 00 [Siemens C45] <-- DELETE [Siemens C45] 0x8A 0x81 0xC8 0xB6 0xB1 0x8F 0x06 0x73 0x07 0xE6 I should be ********** New IMEI = 099999-00-123456 ********** ************************************************* IMEI Block 00 0x8A 0x81 0xC8 0xB6 0xB1 0x8F 0x06 0x73 0x07 0xE6 And at last line, there is two empty line after the last * 0x4D 0x61 0x7B 0x42 0xB8 0x0F 0xDB 0x64 0x6F 0x4F 0x13 0xE8 ************************************************* FIRST EMPTY SECUND EMPTY It should work |
Any new solution for W850 display problem? | jawad8305 | Sony Ericsson Hardware Repair | 7 | 06-12-2010 05:30 |
The new solution for all new sagem phones here :| | maher_teamoo | Infineon C16X M51 & ARM7 M52 BASED | 17 | 09-11-2002 23:27 |
Explain New Solution for 2118 by eriko | Sixth`SenSe | x1x to x45/x50 | 8 | 08-30-2002 21:14 |
