Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 07-18-2006, 21:00   #1 (permalink)
Member: 36782
Thanks Meter: 2
siemens ax72 full flashing procedure+full flashfile wanted
its a big hello to all the experts out there.......siemens ax 72 dead after unlock with joker...please help me with full flashfile and step by step procedure of flashing with joker...
my e mail [email protected]
The Following 2 Users Say Thank You to chrizop For This Useful Post:
Old 07-19-2006, 12:16   #2 (permalink)
.::Mystic::.'s Avatar
Member: 264570
Thanks Meter: 23
1. Download Full repair flash from here
2. Download Joker easy edition from here
3. Open Joker easy edition
4. Select phone model, com-port... (like you did when you unlocked your mobile)
5. Write the AX72 repair flash you just downloaded
6. Go to SKEY tab and press Unlock/Repair
Done!
The Following User Says Thank You to .::Mystic::. For This Useful Post:
Old 07-19-2006, 20:03   #3 (permalink)
Member: 36782
Thanks Meter: 2
ax72 still dead plze help
hello mystic,
thanx four your heIEMENS AX72 lg91 Sw01
Soft FlashID: 0001/2221
FlashID: 0001/227E-2221-2201
Flash Size: 16Mb, WriteBuffer: 32 bytes
Region(1): Blocks 128, Size 128Kb
Start EEPROM segments at addres 0x7A0000
FSN: 0A6C0750 -> PhoneID: 50076C0A
OTP IMEI: 359229002017103
HASH: 9EB12137084C8E74051789B70592CC64
Use OTP IMEI: 359229002017103
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
Read BCORE addr: 0x800000 size: 0x020000...
BCORE backup in ".\Backup\AX72lg91Sw01_BCORE_060719204203.bin" file.
Write BCORE at addr: 0x800000...
Change BCORE HASH - Ok.
Read EEPROM addr: 0x7A0000 size: 0x060000...
EEPROM backup in ".\Backup\AX72lg91Sw01_EEPROM_060719204249.bin " file.
Write EEPROM addr: 0x7A0000 size: 0x060000...
Change BOOTKEY - Ok.
Change EEP0076 - Ok.
Change EEP5009 - Ok.
Change EEP5077 - Ok.
Change EEP5121 - Ok.
Change EEP5122 - Ok.
Change EEP5123 - Ok.
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
The phone was switched off on an error:
EXIT: D500 08 0000
Start...
Cancel.
Start...
EXIT: D500 08 0000
Start...
EXIT: D500 08 0000
lp.......after loadin software this is what i get from joker....
by the way the oriiginal software was ax72lg98 sw02....
helppppp
Old 07-19-2006, 23:28   #4 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
EXIT: D500 08 0000 - Dead CPU , try to rehot it
Old 10-11-2006, 15:41   #5 (permalink)
albarka network's Avatar
Member: 82693
Thanks Meter: 12
........the link is dead,pls upload the file again.i need FF for JOKER.....AX72
i will be very appriciative if i get it.
thanx in advance.
REGARDS.
Old 11-15-2006, 18:11   #6 (permalink)
Member: 290403
Thanks Meter: 5
Done!
the link is not good
Old 03-09-2007, 13:33   #7 (permalink)
Member: 11288
Thanks Meter: 23
e-gold joker flashes
please i need to download full flashes with eeprom and bootcore for all simens e-gold phones to use with joker
can someone give me a link to download those flashes
thanks in advance
Old 10-29-2007, 14:08   #8 (permalink)
Member: 143648
Thanks Meter: 179
link dead plz post new link
Old 10-29-2007, 14:38   #9 (permalink)
faisi's Avatar
Member: 143322
Thanks Meter: 35
Link is dead post the link again.
Thanks.
Old 10-29-2007, 17:09   #10 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Thanks.
...go to http://www.gsmsimlocking.com/Gsm/ind..._Support/AX72/
user : gsmsimlocking
pass : freefornow
and download "AX72_FF.rar"
About the Joker, download from http://www.gsmsimlocking.com/Gsm/ind...Main_Software/
Br,
dagos
The Following 2 Users Say Thank You to dagos For This Useful Post:
Old 09-08-2009, 02:50   #11 (permalink)
fawzi faouzi's Avatar
Member: 219093
Thanks Meter: 14
Lightbulb
pass : freefornow
Br,
dagos
Hello, i can't flash my AX72 , but i can with JOKER > SERVICE > SERVICE MODE > DEL INSTANCES > DEFRAG EEP > ... = always phone dead ... you can help me with any solution for this dead phone please ...
Old 09-08-2009, 04:04   #12 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...I give to you solution. FULLFLASH your phone included bootcore area. Make testpoint and use SERVICE cable for connection. That is.
dagos
Old 09-08-2009, 18:58   #13 (permalink)
Member: 219093
Thanks Meter: 14
Lightbulb
dagos
Thanks dagos to your reply, to use SERVICE cable for connection is special cable or what please ... ... i have one cable test point for UBL ... is that?
Old 09-11-2009, 19:50   #14 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...serial service cable for E-gold phones use only RX, TX and GND way. USB service cable for E-Gold phones is DCA510.
dagos
Old 09-20-2010, 11:59   #15 (permalink)
baabarash1's Avatar
Member: 1396458
Sonork: 100.1591210
Thanks Meter: 29
lm also facing the same problems.
any time l use joker to format a phone then it go dead.l dont know what do with the joker
plz can anyone help me to solve this problem
help me out of this
by the way Mystic,the link is not working
V235 Full Flash for SMART CLIP Wanted blaiseid Motorola P2k 10 09-20-2008 07:00
need full flash procedure of red blinking k300i..........urgent manish665 Cruiser Suite 0 06-25-2007 10:05
gx 15 dead FULL FLASH PROCEDURE.............. hiteshhitesh Sharp 7 11-24-2005 19:54
M50 Full flash SWUP with greek wanted! GSM Coolhawk E-Gold Based Phones 1 05-15-2003 15:01
Full flash for Trium Aria @ wanted tcfx44 Mitsubishi 0 08-24-2001 12:20
Page generated in 0.22151 seconds with 9 queries
