E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
08-29-2006, 12:07 | #78 (permalink) |
Freak Poster Join Date: Oct 2005 Location: jogjakarta Indonesia Age: 46
Member: 192822 Status: Offline Thanks Meter: 18 | a70 dead hi BB GSM can u help me.. i have a70 dead this is result using joker 3.43 but phone still dead. what's wrong? Open file "C:\Program Files\SST-GSM\a70\A70\A70_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A70 Sw13 lg98 RealLgPack: lg1 Start... BootKey: 6E75747A6F6973746865626573740000 Error: StartBoot answer code 0x00A5! Open file "C:\Program Files\SST-GSM\a70\A70\A70_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A70 Sw13 lg98 RealLgPack: lg1 Start... BootKey: 6E75747A6F6973746865626573740000 Error: StartBoot answer code 0x00A5! Open file "C:\Program Files\SST-GSM\a70\A70\A70_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A70 Sw13 lg98 RealLgPack: lg1 Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg1Sw32_Backup060729174632.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. BCORE prepared for Freeze - Ok. Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "C:\Program Files\SST-GSM\a70\A70\A70_80-40_FF.bin". Write Flash addr: 0x800000 size: 0x400000 - Ok. Use Freeze! Freeze... No Ping mobile Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. MobileMode: Service HWID: 241 (A70) A70 lg98 Sw13 25.05.05 16:29:10 IMEI: 359068007651098 DisplayID: 52, Hyundai D0986EF FSN: 875392BA SW FlashID: 0001/220C Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0C): Keys miss in BCORE (CleanBCORE) Code(13): Complete access to BFB Code(15): Complete condition Code(1A): Block 76 is accessible Code(1C): Block 5123 is not found Battery Voltage 4099 mV. SecurityMode: Factory Get IMEI... IMEI: 359068007651098 Freeze... Use IMEI: 359068007651098 Freeze: IMEI Freeze Failed or OTP IMEI is already written! Freeze BCORE data - Ok. Freeze... Use IMEI: 359068007651098 Freeze: IMEI Freeze Failed or OTP IMEI is already written! Freeze BCORE data - Ok. Reparation of the block EEP0071 for disable "aircraft check" and adding of the "Band selection" menu... HWID: 241 (A70) The block EEP071 has not customizations for "Any operator"! Cancel. Reparation of the block EEP0280 for enable "Developer Menu"... HWID: 241 (A70) EEP0280 block is written in ".\Backup\A70lg98Sw13_0280_060729175447.eep" file. Write block 0280 - Ok. "Developer Menu" enabled. Âñòàâüòå SIM ñî ñïåö íîìåðîì. The block EEP0280 is updated. Start... Phone off! Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg98 Sw13 Soft FlashID: 0001/220C FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Use OTP IMEI: 359068007651098 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xBC0000 size: 0x030000... EEPROM backup in ".\Backup\A70lg98Sw13_EEPROM_060729175517.bin" file. Write EEPROM addr: 0xBC0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg98 Sw13 Soft FlashID: 0001/220C FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Boot terminated. Test and Calc Skey... Warning: BOOTKEY not valid in Joker.ini! Real BOOTKEY: C3EE0C629C6FE5BF7387FD3AE1E45EFD! Write correct BOOTKEY? BOOTKEY: C3EE0C629C6FE5BF7387FD3AE1E45EFD SKEY: 12345678 Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. MobileMode: Service HWID: 241 (A70) A70 lg98 Sw13 25.05.05 16:29:10 IMEI: 359068007651098 DisplayID: 52, Hyundai D0986EF FSN: 875392BA SW FlashID: 0001/220C Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0D): Keys are registered in BCORE Code(13): Complete access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 4099 mV. SecurityMode: Factory Send SKey(12345678)... Phone Off. SKey Send: Ok! All Close. |
08-29-2006, 22:52 | #80 (permalink) |
No Life Poster Join Date: Aug 2004 Location: România
Member: 76629 Status: Offline Thanks Meter: 76 | Look at the back label on the phone... If it says SIEMENS, you need to write the flash content from the same type of phone. If on the back label is writed BENQ, you need a fullflash from another A70 BENQ phone. Write only the coresponding FullFlash, than RecalcAllKeys! Easy, isn't it? If someone need A70 FullFlash backup, both SIEMENS and BENQ type, feel free to enter my HomePage, there is a link to my FTP Server. Go to SIEMENS folder, E-gold.. username:forum password:gsmhosting.com Anonymous login not allowed. |
08-30-2006, 09:09 | #81 (permalink) |
Member: 192822 Status: Offline Thanks Meter: 18 | my phone is BENQ.. do you know whats the different of A70 siemens and BENQ? thanks before.. fastlink.. big thanks for the link from hackgsm.. i will try it and will post the result.. fastlink Last edited by Chris02; 08-30-2006 at 19:43. |
08-30-2006, 10:04 | #82 (permalink) |
Member: 192822 Status: Offline Thanks Meter: 18 | BIG THANKS...... HACKGSM.. your file working.. phone working now. this is result of joker 3.43 Open file "C:\a70\benq\A70_80-40_FFBNQ.bin" for write in Flash. FullFlash file info: FlashID: 0001/221D SIEMENS A70 Sw32 lg98 RealLgPack: lg4 Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg98 Sw13 Soft FlashID: 0001/220C FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg98Sw13_Backup060730154335.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim WriteFlash: Segment Size error=0x00 at block 0x800000! Open file "C:\a70\benq\A70_80-40_FFBNQ.bin" for write in Flash. FullFlash file info: FlashID: 0001/221D SIEMENS A70 Sw32 lg98 RealLgPack: lg4 Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg98 Sw13 Soft FlashID: 0001/220C FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg98Sw13_Backup060730154403.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. BCORE prepared for Freeze - Ok. Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "C:\a70\benq\A70_80-40_FFBNQ.bin". Write Flash addr: 0x800000 size: 0x400000 - Ok. Use Freeze! Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. MobileMode: Service HWID: 241 (A70) A70 lg98 Sw32 18.08.05 10:40:31 IMEI: 359068007651098 DisplayID: 52, Hyundai D0986EF FSN: 875392BA SW FlashID: 0001/221D Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0C): Keys miss in BCORE (CleanBCORE) Code(13): Complete access to BFB Code(15): Complete condition Code(1A): Block 76 is accessible Code(1C): Block 5123 is not found Battery Voltage 4084 mV. SecurityMode: Factory Get IMEI... IMEI: 359068007651098 Freeze... Use IMEI: 359068007651098 Freeze: IMEI Freeze Failed or OTP IMEI is already written! Freeze BCORE data - Ok. Start... Phone off! Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A70 lg98 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 875392BA -> PhoneID: BA925387 OTP IMEI: 359068007651098 HASH: 1B60DCF79E8FF6A4517792FA8798AEE2 Use OTP IMEI: 359068007651098 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xBC0000 size: 0x030000... EEPROM backup in ".\Backup\A70lg98Sw32_EEPROM_060730155314.bin" file. Write EEPROM addr: 0xBC0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. |
09-02-2006, 12:24 | #83 (permalink) | |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | unable to download?????????????/ Quote:
09-02-2006, 12:52 | #84 (permalink) | |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | uable to copy Quote:
09-03-2006, 21:53 | #85 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Mirpur-10.DHAKA
Member: 321796 Status: Offline Thanks Meter: 65 | [QUOTE=BB-gsm;1678176]Tools used : Joker v3.4.3 Flash Files : 4MB_220C, 4MB_221D, 8MB_220C 1) Check your A70 Flash IC (Can be done easily, at Skey page: "Recalc all keys") You`ll see: FlashID: 0001/227E-221D-2200 Flash size: 4Mb Or FlashID: 0001/220C Flash size: 4Mb (or 8Mb) 2) Use proper Flash file ! 3) Archive password: Tbilisi Thanks a lot........................................... what about""""""""START BOOT DOESN'T ANSWER""""""""""""".or"""""START BOOT OK BUT MAIN BOOT DOESN'T ANSWER''''''''''''''' some times i face that kind of prob. PLS TELL.what will i do then>>>> |
09-12-2006, 21:53 | #87 (permalink) |
Freak Poster Join Date: Nov 2002 Location: neverland Age: 45
Member: 18165 Status: Offline Thanks Meter: 12 | hellooo i have a problem with a 70 the phone was never opened beofre and came dead to me customer said that the phone died by itself and there are no signs of bad handling by the user i made testpoint but the phone doe's not power when i try to power it when joker asks for it there is nothing not main boot does not answer or something like that like the power on button is not working what could be the problem i cannot recalcc i cannot flash because the button for power is not working or the phone has some other damage or i'm doing something wrong?????? |
09-30-2006, 10:36 | #89 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: My country is Kenya. Age: 39
Member: 153875 Status: Offline Thanks Meter: 35 | Password required Quote:
What is the password for the files mate? | |
09-30-2006, 16:32 | #90 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Brazil Age: 44
Member: 77651 Status: Offline Thanks Meter: 21 | What that kind of error... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com2 460800 BAUD: Ok. SIEMENS A70 lg98 Sw14 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb EEPROM segments not found! FSN: C5B47A56 -> PhoneID: 567AB4C5 OTP IMEI: 356469003247449 HASH: 2276D36132FD0B84E553F839D211F85E Use OTP IMEI: 356469003247449 Error: Not valid addres EELITE in set phone model! |
Repair ALL SX1 here | BB-gsm | E-Gold Based Phones | 110 | 03-26-2022 15:25 |
Repair all alcatel here!!! | libra202 | Alcatel TCL Hardware Repair | 72 | 02-20-2016 18:28 |
Repair ALL A65 here ... ;-) | BB-gsm | E-Gold Based Phones | 298 | 07-04-2011 21:06 |
Repair all A75 here | .::Mystic::. | E-Gold Based Phones | 15 | 01-12-2008 15:10 |
Repair all CF62 here | .::Mystic::. | E-Gold Based Phones | 34 | 12-01-2007 06:02 |
