S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
08-21-2005, 02:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 93339 Status: Offline Thanks Meter: 27 | C66 (C65) V.56 DEAD WITH SAVE ALL Siemens Eeprom Tool Thanks a lot Paul |
08-21-2005, 16:48 | #4 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
Try first to unlock the phone! Probably this wil already help you | |
08-21-2005, 17:08 | #5 (permalink) | |
Freak Poster Join Date: Jun 2002 Location: Spain Age: 52
Member: 13239 Status: Offline Thanks Meter: 3 | Quote:
Good Luck | |
08-22-2005, 09:48 | #7 (permalink) | |
Good Luck | |
08-22-2005, 16:00 | #8 (permalink) |
Member: 93339 Status: Offline Thanks Meter: 27 | Hi. I tried this method. I have a problem when writting eeprom... i get ERROR 15 in siemens eeprom tool. i Can't write blocks 5008, 5009, 5077... i Get this error: ERROR 15 (WBLOCKINFOQUERY) WHILE WRITING BLOCK 5008 ... ABORT RETRY IGNORE ... if i retry i get the same error always... i cant ignore it but the phone doesn't get repaired... Help please |
08-22-2005, 16:36 | #9 (permalink) |
Member: 93339 Status: Offline Thanks Meter: 27 | Finally i can get it working... i have to CLEAR ALL EEPROM DATA with Papuas Clear EEFULL and Clear EELITE... then i restore all the eeprom data with siemens eeprom tool, next i replaced 76, 5008... with papuas... and... the phone is live again!! Thanks for all the help. |
08-22-2005, 17:46 | #11 (permalink) | |
Try to downgrade your phone to minor version and you will change it, with non easy method but it's posible. Regards | |
08-23-2005, 00:26 | #12 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: World Wide Age: 55
Member: 120932 Status: Offline Thanks Meter: 58 | Quote:
If You have siemens X65, X70 serie any SW wich only "beep" when You try to power on, You gona need: -PapuaUtilits0.38d(U can use any, but these one is translate on english), 0.46 to work with AMD flash IC-s -Test Point(no mether what sw is in Your phone!!!!!) -V_Klay, X65Flasher, MartechII, SST(original) to do a full flash off Your phone (U don't have to do full flash, try to do the procedure without full flash the phone. If not work, first do the full flash!!!) Make the TP, put Your phone on cable(COM), run PapuaUtilits and go to section "Flash". Check "Recalculate Keys in Flash" and Papua by hem self, cheks "Replace 76,5008,5009,5077", "Replace Master". It's must be checked too "Pause", and You can make "Make Backup".Put TP on the ground , Click on the "DO JOB". Papua say's "Pause 2" and than You relase TP from GND. Papu starts to doing the job. At the end Papua says "Phone need to be Freeze". Then You go to section Settings off Papua, put Your phone in Service mode(must be on the display off phone), go to section "Various". click on "Read IMEI from phone", and when Papua read IMEI from phone click on "Freeze". Take the phone off from cable. If You try to power on the phone...PHONE IS LIVE AGAIN. I check these procedure for several times and everytime it's working just like I discrabe above. After You doing these, You CAN'T use Winswup, phone is unlocked(and U CAN'T use any unlocking SW on hem, becose he become dead again), but always U CAN use the same procedure on "beeping" phones. And one more time:MARTECH, SST(original) CAN'T REPAIR THESE PROBLEMS, BUT CAN MAKE THESE PROBLEMS ON PHONES(I check these by my self) Cheers p.s. Sorry but must to wrote these again THANK'S TO PAPUA TEAM! YOU ARE THE BEST | |
08-23-2005, 03:01 | #13 (permalink) |
Major Poster Join Date: Dec 2003 Age: 56
Member: 47416 Status: Offline Thanks Meter: 0 | "Save All" = Absence 76,5008, 5009, 5077, 5121, 5122, 5123 blocks in EEPROM. If there are not 5121, 5122, 5123 blocks, it is impossible to write 76, 5008, 5009, 5077 blocks and not work Skey! Use patch "Open Hidden EEPROM" or write FullFlash + "Recalk"... |
Siemens EEPROM tool by skylord v3.15 - problem with LOAD ALL option | PSG | Siemens-Benq RingTones and WallPapers | 5 | 07-22-2005 10:21 |
help, error with siemens eeprom tool by skylord | njben | S-Gold Based Phones | 8 | 03-03-2005 08:24 |
Can not connect C65 with Siemens Eeprom Tool | Anno | S-Gold Based Phones | 3 | 12-19-2004 21:38 |
About phone dead by Siemens Eeprom tools | sschn07 | S-Gold Based Phones | 2 | 11-15-2004 11:02 |
does siemens eeprom tools by skylord work under win2k? | eio | Siemens-Benq RingTones and WallPapers | 0 | 05-02-2003 08:24 |
