Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-13-2003, 04:48   #1 (permalink)
Member: 26497
My phone is just only display digital clock when key is locked,pls help me!
My phone is just only display digital clock but others patch is work correctly.
This is my partial patch data about selectable operate logo
0x3AC464: F2F6763F DAC744D1
0x3B0362: 46FC2200 DAC730D1
0x3B0D4C: DACB78CA DAC720D1
0x3B3804: DAA5983F DAC746D1
0x27D120: FFFFFFFFFFFFFFFF DACB78CAE012D740
0x27D128: FFFFFFFFFFFFFFFF 3400F7F41B3EDB00
0x27D130: FFFFFFFFFFFFFFFF 48C1FD05E004D740
0x27D138: FFFFFFFFFFFFFFFF 3400F7F81B3E46FC
0x27D140: FFFFFFFFFFFFFFFF 2200DB00F2F6763F
0x27D148: FFFFFFFFFFFFFFFF 0DF5D7400E00C200 ; I don't want to have digital clock when key is locked ,so I mask 0x27D14F to 00
0x27D150: FFFFFFFFFFFFFFFF 423A46F955012D1E
0x27D158: FFFFFFFFFFFFFFFF D7503400F3F41B3E
0x27D160: FFFFFFFFFFFFFFFF F2FE1C3E49402D13
0x27D168: FFFFFFFFFFFFFFFF 8AF114509AF10F40
0x27D170: FFFFFFFFFFFFFFFF 08E146FE0A008D01
0x27D178: FFFFFFFFFFFFFFFF E00ED7403400F6FE
0x27D180: FFFFFFFFFFFFFFFF 1C3E06FE8702E00C
0x27D188: FFFFFFFFFFFFFFFF E08DDAC1EC22DAA5
0x27D190: FFFFFFFFFFFFFFFF 983FDB00E00CE0BE
0x27D198: FFFFFFFFFFFFFFFF BB27E00CD7500D00
0x27D1A0: FFFFFFFFFFFFFFFF F2F1DE25F2F2DC25
0x27D1A8: FFFFFFFFFFFFFFFF 8820BB11E6FEFFFF
0x27D1B0: FFFFFFFFFFFFFFFF D740340054FE1C3E
0x27D1B8: FFFFFFFFFFFFFFFF DD0306FC0D000D04
0x27D1C0: FFFFFFFFFFFFFFFF E0AEBB1226FC0900
0x27D1C8: FFFFFFFFFFFFFFFF 9810BB010DE0E0A2
0x27D1D0: FFFFFFFFFFFFFFFF F6F10EFE5B22F2F1
0x27D1D8: FFFFFFFFFFFFFFFF 0CFE8810F2FE0EFE
0x27D1E0: FFFFFFFFFFFFFFFF BB0398E0BB01CB00
0x27D1E8: FFFFFFFFFFFFFFFF 88C006FE3401E08D
0x27D1F0: FFFFFFFFFFFFFFFF DAC1EC2298C006FC
0x27D1F8: FFFFFFFFFFFFFFFF 1600CB00FFFFFFFF
0x4BAE56: 1E070100AD1FAC03 162F01002023AD03
0x4BAE5E: 1E070100C91FAC03 162F0100B023AD03
0x4BAE66: 1E070100E51FAC03 162F01003027AD03
0x4BAE6E: 1E0701000120AC03 162F0100C027AD03
0x4BAE76: 1E0701001D20AC03 162F0100402BAD03
0x4BAE7E: 1E0701003920AC03 162F0100D02BAD03
0x4BAE86: 1E0701005520AC03 162F0100502FAD03
0x4BAE8E: 1E0701007120AC03 162F0100E02FAD03
0x4BAE96: 1E0701008D20AC03 162F01006033AD03
0x4BAE9E: 1E070100A920AC03 162F0100F033AD03
0x4BAEA6: 1E070100C520AC03 0D2F01007037AD03
0x4BAEAE: 1E070100E120AC03 652F01002008AE03
0x4BB8EF: 50 2F
0x4BB8F7: 50 2F
0x4BB8FF: 50 2F
0x4BB907: 50 2F
0x4BB90F: 50 2F
0x4BB917: 50 2F
0x4BB91F: 50 2F
0x4BB927: 50 2F
0x4BB92F: 50 2F
0x4BB932: 1004AE036550 7002AE03652F
0x4BB93A: 2008 E004
What is it wrong?
Old 11-14-2003, 02:02   #2 (permalink)
Member: 26497
Rizapn,Why did it not work with my phone?
I change offset
0x27D14F: FF 00 to 0x27D157: FF 00 that it can work correctly
Selectable Operator Logo Post #126 of 136
;*** SOL. Selectable Operator Logo (New version) ***
;Firmware : SL45v56
;Author : RizaPN
;Release : November 3, 2003
;Modified : November 8, 2003
;Please undo the previous "Selectable Operator Logo" patch.
;Using this version, animated operator logo or digital clock will
;be displayed even the network is not the home network.
0x27D148: FFFFFFFFFFFFFFFF 0DF5D7400E00C2F1
0x4BB8EF: 50 2F
0x4BB8F7: 50 2F
0x4BB8FF: 50 2F
0x4BB907: 50 2F
0x4BB90F: 50 2F
0x4BB917: 50 2F
0x4BB91F: 50 2F
0x4BB927: 50 2F
0x4BB92F: 50 2F
0x4BB93A: 2008 E004
;If you DO NOT want to have Digital Clock when the Key is locked, use this also :
;0x27D14F: FF 00
;If you DO NOT want a blinking colon in the Digital Clock, add this :
;0x27D1B8: FF 0D
;- This patch use firmware image no. 309 - 318 as a Digital Clock number (image size is
;22x47), image no. 319 as a colon (image size is 13x47), and image no. 320 as a clock
;background.
;- Image No. 648 - 657 as an Animated Operator Logo (image size is 101x47).
;- Modify those images using my ffmod or any other Siemens picture modifier, just after
;applying this complete patch.
;This patch is selectable from the "new" Setup->Application menu.
Old 11-14-2003, 08:18   #3 (permalink)
DjCook's Avatar
Member: 20879
You can Try this, if You do not like Digital Clock while Keys are Locked:
0x27D156: 2D 00
Old 11-14-2003, 21:32   #4 (permalink)
Member: 41707
Tested, but works reverse than should. I mean when i unlock keys i get my anim. logo and when i lock 'em i get the digi clock.
Old 11-15-2003, 01:38   #5 (permalink)
trustkill's Avatar
Member: 27745
Tested, but phone turns off !
Old 11-17-2003, 10:51   #6 (permalink)
Member: 26497
DJcook posted wrong offset.
It must be
0x27D157:1E 00
Old 11-17-2003, 14:11   #7 (permalink)
trustkill's Avatar
Member: 27745
It must be
0x27D157:1E 00
This causes following effect(s):
Digital Clock ON and Keylocked: Show Digital Clock
Digital Clock OFF and Keylocked: Show Logo
Animated Logo ON an Keylocked: Show Animated Logo
All Off: Show Logo
BUT I want the following:
Digital Clock ON an Keylocked: Show Animated Logo
Isn´t it possible ????
Old 11-21-2003, 22:17   #8 (permalink)
trustkill's Avatar
Member: 27745
If you want to select the LOCKED state use this
;0x27D156: 2D 3D
In UNLOCKED state always digital clock is visible
Old 11-23-2003, 00:50   #9 (permalink)
Member: 42457
Isn't is possible to do the following?
If keys aren't locked then show always the normal Background image
If keys locked you can select what you want (Digi Clock, Animated logo or only Background)
It would be nice if someone can implent a feature in the Application Menu from Riza with a point what to do if keys are locked or unlocked.
Annother Problem what I have is that in Roaming mode a Backgroundimage can't be showen. Do you think that this is solveable? I use O2 (Germany) as provider and in my region this net isn't available
Old 11-23-2003, 11:56   #10 (permalink)
trustkill's Avatar
Member: 27745
If keys aren't locked then show always the normal Background image.
Here it is, just made for you
;0x27D156: 2D 3D ;LOCKED state is selectable through the new menu !
;in UNLOCKED state is always Digital-Clock (0x27D157=1E)
;0x27D157: 1E 00 ;Show same when keys locked/unlocked
;0x27D157: 1E 03 ;Show always normal background image when keys are unlocked
Old 11-24-2003, 13:26   #11 (permalink)
Member: 42457
Thx trustkill, saw it yesterday used it today and it works excellent
But I've a problem with the background image. My phone is always in Roaming mode (I use o2-Germany) and the Roaming net is T-Mobile. So I always see T-Mobile on my Display and not the damned background image. I asked Riza and he work on that problem - hope he'll solve that.
Do YOU think it's solveable? BTW you're also german - or am I wrong?
Bye
Bean
sl45.darkzone.lu
Old 11-24-2003, 16:57   #12 (permalink)
DjCook's Avatar
Member: 20879
It must be
0x27D157:1E 00
No!
This adress is not wrong!!
You can change offset to:
00
2D
3D
Try one of them..
Old 11-24-2003, 18:07   #13 (permalink)
Member: 41707
@Dj Cook
What do each of them do?
Old 11-24-2003, 20:50   #14 (permalink)
trustkill's Avatar
Member: 27745
Mostly everything is possible I think. But I´m not that "coder" like Riza or others.... I just can do "trial and error" ......
Und: Ja ich bin aus Deutschland, mail mir mal....
Old 11-24-2003, 23:39   #15 (permalink)
Member: 41707
Yes but when you tried these values, what was the result?
Und: Viele grüßt von Griechenland!!!
My Sagem Mc 922 Sim locked pls Help me varma raj Infineon C16X M51 & ARM7 M52 BASED 1 06-28-2003 08:19
I want to unlock SP LOCK PLS HELP ME 3310 varma raj Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-10-2003 19:13
I want to unlock SP LOCK PLS HELP ME 3310 varma raj Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-05-2003 04:41
Page generated in 0.20017 seconds with 10 queries
