11-25-2003, 03:11 | #16 (permalink) |
Junior Member Join Date: Apr 2003 Location: Bkk,Thailand Age: 46
Member: 26497 Status: Offline Thanks Meter: 0 | I'm Sorry for my last posted Your data offset that you refer to is correct and my data offset that i refer to is correct too. trustkill add them to SOL trick patch |
11-28-2003, 08:16 | #17 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | @yiourkas The result was (I used that the locked status works reverse and that the Backgroundimage is viewable) On Keylock ON I can change between Clock, Logo or Image On Keylock OFF ALWAYS Background image can be seen But there's a bug. If I call someone then the two phone stand together but the DigiClock also can be seen. You see the two phones for the moment and then you see the DigiClock and so on..... It's a bit...well...looks ugly |
11-28-2003, 18:16 | #18 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | ....and moreover my net provider isn't available all the time so my phone is always in roaming mode. That means I never see the background image. Maybe Riza or annother coder can make a entry into the APP menu so that the logo can switched to be visible? |
12-13-2003, 14:55 | #19 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
12-13-2003, 21:39 | #20 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 41707 Status: Offline Thanks Meter: 1 | trustkill this happens to me only if the following happen (In this order) 1)Lock keyboard 2) someone calls me, I miss the call 3) Go to missed calls without unlocking keys (using rizapn's patch) 4) Call him back. |
My Sagem Mc 922 Sim locked pls Help me | varma raj | Infineon C16X M51 & ARM7 M52 BASED | 1 | 06-28-2003 08:19 |
I want to unlock SP LOCK PLS HELP ME 3310 | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-10-2003 19:13 |
I want to unlock SP LOCK PLS HELP ME 3310 | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-05-2003 04:41 |
