x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones). |
01-14-2005, 13:08 | #62 (permalink) |
Junior Member Join Date: Mar 2003 Location: Jakarta Age: 47
Member: 24347 Status: Offline Thanks Meter: 0 | help this pacth : ; Enable Dev Menu CX65 V25: (C)SiNgle A1336914: 04 08 - AND - ; CX65 v25 open disk forever A135A5D8: 02 03 that pacth is not work, message error... Why ? can help me please... thanks. |
01-14-2005, 14:00 | #63 (permalink) | |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | Quote:
About detail in the topic of your post(readybb.com/siemensxp/viewtopic.php?t=440),could you explain this detail in English? i have one no-name M55 cable and i still cant find any DCA 510 ,so i need to upgrade CX65 with my old data cable thank for advice(again) | |
01-17-2005, 04:57 | #64 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: www.SiemensXP.com Age: 45
Member: 49922 Status: Offline Thanks Meter: 0 | Quote:
1. Connect x65 via Cabel in COM1/COM2 (Phone ON) 2. Run ATEnabler v2.0 * If phone goes OFF, Turn it ON and do step 2 again. 3. Select which COM that cable attached, and klik "connect" 4. Klik "Enable & Check AT" 5. Please wait until message : "x65 Found!" 6. Klik "Exit" 7. Run updater tool x65 v25 8. When updater scanning port, probably the phone will not detected. (if phone OFF just continue the step) and updater will prompt to use manual setting. 9. Set manually the COM port where the cable attached. * if phone OFF in step 8, turn ON the phone. 10. Continue step on screen, until the message : "Press ON/OFF..." and press the On/Off button in phone. 11. The Updater should be starting the update process in this moment.. 12. Wait for 20-30 minutes. 13. finish.. Hope it works in your phone.. | |
01-17-2005, 05:02 | #65 (permalink) | |
* I think that patch is good & no problem. Pls check your hardware & setting (cable, PC-SisOp, V_Klay version, etc.) | |
01-17-2005, 05:43 | #66 (permalink) |
Member: 24347 Status: Offline Thanks Meter: 0 | @Pak_Tani i sure, cek my phone with *#06#... my phone CX65 v25. i use other pacth in this forum with V_Klay v3.1, 100% work... but pacth for "enable dev menu" and "open disk forever" not work. Why ?? thanks for help. |
01-17-2005, 12:23 | #68 (permalink) | |
I found this from AsteriX website: ;* Opened Discs Forever * © SiNgle ; CX65 v25 135A5D8: 02 03 but I can not found the Dev Menu Patch. | |
01-17-2005, 15:47 | #69 (permalink) | |
Junior Member Join Date: Apr 2004 Age: 45
Member: 63174 Status: Offline Thanks Meter: 0 | Quote:
; CX65 v25 open disk forever (Ñ)SiNgle 135A5D8: 02 03 ;CX65v25_EnableDevMenu (Ñ)SiNgle 1336914: 04 08 | |
01-18-2005, 09:45 | #70 (permalink) |
Junior Member Join Date: Jan 2005 Location: Italy
Member: 107480 Status: Offline Thanks Meter: 0 | Patches translation Can somebody translate this? (M65 v25) ;* ????????? ??????????? ? ???? * © *S*h*a*D*o*W*, ® ILL!, § Serega_1 15561DC: 55555555555555555555555F FFFFFFFFFFFFFFFFFFFFFFFF ;???????? ????? ;15561DC: 55555555555555555555555F 8F11E23C4788F11E23C4788F ;?????-????-????? ;15561DC: 55555555555555555555555F 22222222222222222222222F ;?????? ????? ;15561DC: 55555555555555555555555F 00000000000000000000000F ;??????????? ;* ??????? ????? ???? "???? ?????:" ??? ?????? ????? * © SiNgle, § AsteriX 1305DBC: B80B 0100 ;* ?????? ????? ??? ??????? "?????? ??????????" * © B-727 09F1D7E: 1800FAFF0000B6034A0178054A0108074A01FFFFE803F9FF03 00 0C00B8073200FFFF3200400C1A00FFFFFFFFFFFFFFFFFFFFFF FF |
01-18-2005, 10:21 | #71 (permalink) |
Member: 107480 Status: Offline Thanks Meter: 0 | Patches translation Sorry. Can somebody translate this? (M65 v25) ;* Изменение разделителя в меню * © *S*h*a*D*o*W*, ® ILL!, § Serega_1 15561DC: 55555555555555555555555F FFFFFFFFFFFFFFFFFFFFFFFF ;сплошная линия ;15561DC: 55555555555555555555555F 8F11E23C4788F11E23C4788F ;точка-тире-точка ;15561DC: 55555555555555555555555F 22222222222222222222222F ;редкие точки ;15561DC: 55555555555555555555555F 00000000000000000000000F ;отсутствует ;* Быстрый показ окна "Язык ввода:" при выборе языка * © SiNgle, § AsteriX 1305DBC: B80B 0100 ;* Замена звука при дозвоне "ошибка соединения" * © B-727 09F1D7E: 1800FAFF0000B6034A0178054A0108074A01FFFFE803F9FF03 00 0C00B8073200FFFF3200400C1A00FFFFFFFFFFFFFFFFFFFFFF FF |
01-19-2005, 01:41 | #72 (permalink) |
Member: 49922 Status: Offline Thanks Meter: 0 | ; Change of divider in the menu ; © *S*h*a*D*o*W*, § Serega_1 ; M65 v25 15561DC: 55555555555555555555555F 8F11E23C4788F11E23C4788F ; dot-dash-dot line ;15561DC: 55555555555555555555555F 22222222222222222222222F ; rare dots line ;15561DC: 55555555555555555555555F FFFFFFFFFFFFFFFFFFFFFFFF; continuous line ;15561DC: 55555555555555555555555F 00000000000000000000000F ;No line ---------------------------------------------- ; Fast display of a window " Language of input: " at a choice of language ;© SiNgle, § AsteriX ;M65 v25 1305DBC: B80B 0100 ---------------------------------------------- ;* Replacement of a sound at dialing " a mistake of connection " * © B-727 09F1D7E: 1800FAFF0000B6034A0178054A0108074A01FFFFE803F9FF03 00 0C00B8073200FFFF3200400C1A00FFFFFFFFFFFFFFFFFFFFFF FF * you can use online translator here: http://www.online-translator.com/text.asp?lang=en |
01-20-2005, 03:43 | #73 (permalink) | |
Member: 24347 Status: Offline Thanks Meter: 0 | Quote:
Thanks... this patch is success hehe... | |
01-20-2005, 09:38 | #74 (permalink) |
Major Poster Join Date: Jan 2004 Location: Italy Age: 44
Member: 50987 Status: Offline Thanks Meter: 0 | Can someone to make a patch that remove the message: "SIM full!" when receve an SMS for a CX65 FW36? It's a boring message... Another Patch is: Setup Illumination by 2% for CX65 FW36... Last edited by gianlukko; 01-20-2005 at 10:19. |
01-20-2005, 20:59 | #75 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Italy
Member: 26267 Status: Offline Thanks Meter: 1 | Instead I've applied the trick to delete the "click" after making a photo but it doesn't work. I could not find the string "000056..." because it doesn't exist. I put the new string "000027..." but the click still remains... |
M55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 880 | 01-25-2010 05:37 |
[SLIKv56]: Thread for UNI2 | trustkill | x4x, x5x Flashpatching | 36 | 04-04-2007 19:02 |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
Flash patches thread for SLIK56 can be found here..... | cyperghost | Board, Server and Login Problems/Support | 3 | 10-24-2005 18:01 |
