WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
06-04-2004, 23:50 | #1 (permalink) |
Junior Member Join Date: Nov 2003 Location: South Africa Age: 55
Member: 44745 Status: Offline Thanks Meter: 1 | Nokia Engage "yust say nokia then Dead" What can i do to fix it. please help. |
06-06-2004, 20:10 | #3 (permalink) |
Member: 44745 Status: Offline Thanks Meter: 1 | Help Nica Idontrealyknowwhatflashtouse soi tried every one i have got. If you maybe have a program to change the imei an the flash it it wil help. Please it is an expensive phone in my country , and if i tell the cust.. that i cant fix it oh boy.. lots of work down the drain. Please , if it is an hardware problem , i have flow the total bord, all i can think is to change the imei. Afther the flash the imei read 0000 0000 0000 0 , thats realy a problem. i cant change imei on dct4. No software available , can u help , please Jim or Enyone. |
06-07-2004, 13:45 | #4 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Bulgaria Age: 59
Member: 24925 Status: Offline Thanks Meter: 2 | Just say NOKIA I have the same problem, but IMEI is right....Flashed many times with GRIFFIN and v.3.30(the same as original) - no help... Erase flash with erase .bin , flash again with mcu+ppm - now new problem - phone not recognize charger and again say "NOKIA" and go off....(before erase with erase.bin charging was normal) Any help for this? |
06-10-2004, 12:16 | #5 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Next to the small lake, hunting crocodiles:-) Age: 51
Member: 50713 Status: Offline Thanks Meter: 0 | @nica: I meant what FLASHER (hardware) are you using eg: Griffin, Prodigy etc. @johnbye: Have you tried restoring pmm values after using erase.bin? Don't know for sure but that might solve the charging problem, also DO NOT use ADSP flashing with griffin and yes, make sure you only flash with fw that was already on the phone. If MCU and ADSP are different versions phone wont work. |
06-10-2004, 19:34 | #6 (permalink) |
Member: 24925 Status: Offline Thanks Meter: 2 | Yes , version is the same as original....PMM values are restored (backup of original) ADSP flashing - unsuccessful.... Nothing help me to revive this f*****d phone....... |
06-11-2004, 22:07 | #7 (permalink) |
Member: 50713 Status: Offline Thanks Meter: 0 | @johnybye: you need to make .rpl file with original IMEI and upload the .rpl to the phone. P.S. Did you try to flash ADSP? If you are using Griffin your phone is dead. Only way to revive is at Nokia Service point or with Prodigy. Griffin can't flash ADSP and if you tried already your ADSP is now empty. Jim Last edited by Essential GSM; 06-12-2004 at 10:31. |
06-15-2004, 22:37 | #9 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | First you have to erase whole flash by "nem4_fullerase" you'll get this file Griffinteam.net After Full Erase !! its very Simple Flash with Firmwares Write PM Values UNLOCK Format User Area All is OK !!! Post the Results Regards Aamir Zia |
06-21-2004, 12:42 | #10 (permalink) |
Member: 24925 Status: Offline Thanks Meter: 2 | @First you have to erase whole flash by "nem4_fullerase" @Flash with Firmwares After that you will get "No comunication with phone" for unlock and write .pmm (all via M-bus )..... Only flashing is possible |
06-25-2004, 04:00 | #11 (permalink) |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | I have problem like this before, and I have success to fix it. It's the methods : 1. Write nem4_fullerase 2. Write MCU & PPM Without ASDP 3. Unlock It 4. Format User Area 5. Write Ngabe Pm File 6. Unlock it 7. Success..... Regards |
nokia 5130 auto power on then hang with nokia | rumenshom | Nokia Hardware & Hardware Repair | 18 | 06-03-2015 06:53 |
nokia Engage QD hard formeting | hshanda | WD2 & APE (Symbian Phones) | 1 | 08-02-2005 20:41 |
nokia engage rh-29 blinking | gsmservices | WD2 & APE (Symbian Phones) | 1 | 04-29-2005 18:29 |
Nokia 8210 sometimes full signal then no network? | Gfunk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-27-2001 17:35 |
