SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
03-16-2006, 05:47 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 244841 Status: Offline Thanks Meter: 0 | Quick Question about D600 I am also wondering if someone can tell me where i can buy the d500 cable from in Canada!! Please let me know! Thank you I will try to flash in OneNAND Downloader v1.7 MINI If anyone has any tips please let me know I also have another D600 (I think its only D600 not D600E) but its by t=mobile , i will try to unlock it also and reflash with unbranded software but may need help later, so far i have seen this forum to be VERY helpful to newbies so its nice to see a place like this Thanks again!! |
03-17-2006, 15:15 | #2 (permalink) |
Crazy Poster Join Date: Mar 2006
Member: 241979 Status: Offline Thanks Meter: 0 | Hi if you are looking for a 9 volt flashing cable for your samsung d600, then why not try ebay. I got mine from ebay. As for flashing the phone, be careful! Make sure that you use a fully charged up battery and A BRAND NEW 9 VOLT BATTERY. This process can take 90 mins +. Dont make the same mistake I made when I flashed my d600 for the first time, I didnt make sure that the 9 volt battery was connected to the cable securly and when I moved the phone with the cable attached my phone died. It must be connected securely. Here is a tutorial for you. Please note that this is not my tutorial but if you follow it to the letter, you will be ok. Serial Cable Users ------------------ process takes around 90 min. cOPY tHE correct d600 fLASH fOLDER tO yOUR cOMPUTER fROM tHE cd Make sure your D600 Battery is fully charged Connect 9v Battery to Cable, must be a brand new battery as this process takes approx 90 min, and if the battery fails you WILL kill your phone. power off the phone with no sim inserted and connect phone to cable and cable to PC. when flahing d600 make sure you select 1gone at the top select correct com port. com speed should be 115200. select the BIN + TFS radio button. D600 users press the BIN button and open the "D600XAEJ4.cla" file. from the d600 folder Orange users press the BIN button and open the "D600EMYEJ3.cla" file. fom the d600 on orange folder D600 users press the TFS button and open the "D600XAEJ4.tfs" file. from the d600 folder Orange users press the TFS button and open the "D600XAEJ4.tfs" file. from the d600 folder Click Start. tap the power button on the phone when prompted. The phone should not turn on, but software will recognise the ignition. Phone will connect, and the "Download" button will now be highlighted click the download button and the flash will begin Note: the entire flashing process takes approx 90 min. Once flash has finnished, press stop Phone successfully flashed take out and replace battery and power on. Also once the flashing is complete, when you poer the phone on, your imei may be all zeros. You will need to write the imei back onto the phone ( I have flashed the same d600 now 4 times and I have had to re write the imei each time). You can do this with either SUS (swift D600/600E service) or the cracked winimeiD600 which you will find a link for in this forum somewhere. If you follow those instructiosn to the letter, Im sure you will be ok. If for some reason, you kill your phone like I did, just charge the battery up. You will need another d600 to charge it up as your phone, if dead will not be able to charge it up. Use another NEW 9 volt battery just to be careful anf start the flash again. i hope this info helps you. If you are not sure of stuff, just post a new thread in this forum. There will be plaenty of guys willing to help you, there are some good poeple who frequent this forum |
03-18-2006, 02:19 | #4 (permalink) |
Member: 244841 Status: Offline Thanks Meter: 0 | Hey yeah i read your other post about that i am getting the USB cable froma friend in the UK so no battery needed, but gotta find those drivers for it, should be ok. I was just wondering what the altest firmware is for the d600 i currently have these files: D600EXDEK5-CLA D600EXBEK4-TFS I dont know if that for the d600 or the 600E Im looking for the latest one since i may as well get it right up to par if im going thru the trouble I may need a little help on writing the imei (this is the first time i have ever flash a phone, im good with pcs, just never really tried mobile phone stuff before) Thank you for your time Colin |
03-31-2006, 22:15 | #7 (permalink) | |
Insane Poster Join Date: Dec 2005 Age: 39
Member: 210887 Status: Offline Thanks Meter: 0 | Quote:
WinIMEI Help open prog select D600 attach 9v battery to cable attach cable to phone read imei settings press on button on phone will enter tat mode reads for 5seconds show pass in top right corner press Wrt IMEI button only change last 5 digits of original phone imei(not imei in prog) dettach cable from phone dettach battery from phone reattch battery and cable now press Confirm prog will start press on button on phone again will enter tat mode prog is running keep eye on phone as the screen will go black at this point press on button of phone again this wil happen several times every time press on button to re enter tat mode prog will show pass in top right corner again dettach phone check imei *#06# all done hope this helps Ps If You Need The WinIMEI File P/M Me | |
Quick question about PIC16F628 and SimEmu | Gippo | Sim Cloning and Scaning | 0 | 07-01-2006 14:36 |
Quick question about unlock procedure | m_dige | Cruiser Suite | 3 | 03-29-2005 14:57 |
Couple quick questions about 6620 | ronnyek | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-02-2004 20:40 |
A quick question about typical phone service policys. | iceslice | Off Topic Zone | 1 | 08-31-2003 15:26 |
