QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
06-17-2005, 16:39 | #18 (permalink) |
Insane Poster Join Date: Dec 2004 Age: 44
Member: 95076 Status: Offline Thanks Meter: 1 | Look.. The DB9 connector should NOT be connected in ANY way with ANYTHING but the COM1 port on the computer. And on the DB9 you should just connect pin 2 with pin 3.. just solder a cable between them or whatever so that they are connected to eachother. How to use it: Connect it on COM1 before you start winimei. Start winimei, choose your country and press OK. Then press unlock. If you run something in winimei besides unlock like read settings to check the connection is working then quit winimei and disconnect the DB9. Then reconnect it and start winimei again. The usb cable should be connected all the time. Make sure you have installed the usb/modem drivers first. |
06-17-2005, 18:21 | #19 (permalink) |
Junior Member Join Date: Jun 2005 Age: 43
Member: 154082 Status: Offline Thanks Meter: 0 | Just want to confirm that the unlock WORKS! My ipaq 3870 PC-cable has (had) both serial and usb and since I never use the serial contact(DB9) I just cut it off and connected pin 2 and 3 together with small metalthread and then connected to COM1. It didn´t work on my PC at first but I tried on anotherone and it worked rigth away. Now I will try make GPRS work with other network. Anyway I wanted to let you know that it worked also for me and thanks reefer45 |
06-19-2005, 16:41 | #22 (permalink) |
Member: 154567 Status: Offline Thanks Meter: 1 | works 100% this was great, unlocked my girlfriends phone with the standard USB-cable and the "DB9 2-3pin" thing see a picture of the "DB9 2-3pin" thing here: http://nife.no-ip.org/bilder/db92-3pin.jpg ehm.. yes, the "thing" is placed on a mirror |
The Following User Says Thank You to NiFE For This Useful Post: |
06-20-2005, 11:04 | #26 (permalink) | |
No Life Poster Join Date: May 2004 Age: 45
Member: 66871 Status: Offline Thanks Meter: 34 | Quote:
hi reefer45 good work unlock success | |
The Following User Says Thank You to gsmrepair1 For This Useful Post: |
06-20-2005, 18:23 | #27 (permalink) |
Junior Member Join Date: May 2005 Age: 50
Member: 142983 Status: Offline Thanks Meter: 0 | hello! reefer45: can u help me ..! i have flash my z500 roms completed!!! i have to resting..! put 4,0& end key ....! but not success!!! only see red display "Error Fatal dog :startup" what happen for this...! can u help me.....! please my phone can't open now...! please ......! |
06-23-2005, 00:50 | #29 (permalink) |
Junior Member Join Date: Jan 2005
Member: 109638 Status: Offline Thanks Meter: 0 | tjaba Tjoo! tnx beautiuful sulution!! works 100% Just unlocked my own and a friends phone. When I shorted my comport I used a serialcable and shorted pin 2 and 3 as in the instruction like this (Attached Thumbnail) The program I used are: QIWS_V1.16(Service)_041011.exe as instructed in the first thred "started winimei(Z105V1.16.rar) " Tnx again, great work!!! Last edited by micked; 06-23-2005 at 14:27. |
06-26-2005, 18:49 | #30 (permalink) | |
Junior Member Join Date: Feb 2004 Location: Stockholm Age: 57
Member: 53717 Status: Offline Thanks Meter: 0 | Quote:
The CDMA drivers, is it the same ones that are included on the CD with the phone, or some special ones? What is the purpose of the keygen program included, I did not need it to run WinIMEI? I can not change USB modem port on the settings screen, do I need to? When I looked at the .ini-files (Z105U has a file for Telia, the operator that Swedish Z500's are locked to) and some of the branding is defined in those files, sticky bookmarks, MMS settings and more. Does this part of the branding go away when the phone is unlocked? | |
FREE complete unlock solution for Samsung SGH-Z500! | reefer45 | QUALCOMM Models (3G) | 147 | 10-06-2012 14:36 |
Unlock Code Samsung SGH-Z500 | tropiques747 | Samsung Flashers, Software, Firmware. | 7 | 03-23-2009 10:01 |
Samsung SGH-Z500 | karlx | QUALCOMM Models (3G) | 9 | 09-26-2005 16:27 |
What happened to the Z500 complete unlock solution thread? | reefer45 | QUALCOMM Models (3G) | 3 | 08-04-2005 21:43 |
who know correct to flash samsung sgh-z500? | paul8888 | QUALCOMM Models (3G) | 0 | 06-16-2005 19:00 |
