QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
11-28-2005, 22:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2004
Member: 97600 Status: Offline Thanks Meter: 97 | z500 problem rewrite imei and bt address |
11-28-2005, 23:00 | #2 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Just use Original NSDongle software and correct cable and everything will be OK. | |
11-29-2005, 13:48 | #3 (permalink) |
Member: 97600 Status: Offline Thanks Meter: 97 | z500 problem thanks for the reply elco can you tell me what cable i should use? i tried the z500 cale that came with your dongle but it did not work as i said in the previous post your soft says that the imei is done but when i read the settings it is still the same no imei and no bt |
11-29-2005, 15:29 | #4 (permalink) | |
You can find the pinout for correct cable on the support zone.There are 2 cables for Z500: 1.USB cable for unlock 2.Cable for IMEI change | |
11-30-2005, 02:18 | #6 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 69631 Status: Offline Thanks Meter: 42 | ELCO wont tell you cause hes not sure if your useing the cracked version or not !!!!! use the lg 7050 data cable mate and ns dongle. it has to be the one with the 9 volt battery connector. remember , its a com port cable.. 9 pin, not usb works 10000000000000% with ns dongle. you might have to try a couple of times as it seems to work the second or third time for some reason, but bare with it mate. the cable is sold at loads of web sites for between £7 and £10 mate. good luck lolly pop |
12-15-2005, 02:21 | #10 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Mouscron/ Belguim Age: 46
Member: 18703 Status: Offline Thanks Meter: 330 | Quote:
with Z500v and Z140V for Z140v select Z500 model nsdongle cracked + LG 7020 cable 5v = 100% work solution to change imei in Z series | |
World's First Solution for Change IMEI and Bluetooth address of KU990 Without any NV | coolmomisher | LG | 131 | 11-10-2012 09:17 |
VYGISTOOLBOX UPDATE LGQ_1_34SC: LG KB770 direct unlock,IMEI and BT ADDRESS changing | Gobi | VygisToolbox | 8 | 05-03-2009 02:33 |
LG u990 IMEI AND BT PROBLEM SOLVED AFTER UNLOCK | GSMMart | FuriousGold | 7 | 04-11-2009 10:03 |
VYGISTOOLBOX UPDATE LGQ_1_34SC: LG KB770 direct unlock,IMEI and BT ADDRESS changing | Gobi | Service Products News & Updates | 0 | 04-06-2009 12:58 |
03/06/07 Only 17gb Of Fws Added. Imei And Bt Addr Change ! | .:hack3r2k:. | FuriousGold | 43 | 10-20-2007 11:12 |
