Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sagem > Sagem Hardware Repair Area
Sagem Hardware Repair Area All the Discussions for Repairing Sagem Phones are located here, No software Probelms you can find, all inside are Hardware Problems.
Old 07-27-2002, 20:07   #1 (permalink)
kreitzz's Avatar
Member: 8442
Exclamation Battery tatus unknown!?
Hi!
I have 4 Sagem 922 with the same problem: “Battery unknown!” when turn on. Phones also don’t take charge. I changed charging controller, but nothing. Anybody knows how to repair this?
IS NOT BATTERY CONTANTS PROBLEM!!!
Old 09-03-2003, 04:08   #2 (permalink)
Member: 9584
Thanks Meter: 31
i have the same problem with 8 mw3026. can anybody advice som usefull information
best regards
Old 09-29-2003, 15:17   #3 (permalink)
Member: 22505
I have no solution, but some time ago I have problem with outgoing calls with not good akku. Well, after add capacitor to the supply one (yellow under lcd - 477) phone write - "unknow battery" May be it help you.
Old 09-29-2003, 18:19   #4 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,569
Angry ...
Hi !
I got read of this problem by rewritting the eeprom on both m41/m51. But not allways this problem come from bad eep settings.
best regards,
.:hack3r2k:.
Old 09-29-2003, 18:31   #5 (permalink)
Member: 11208
Thanks Meter: 11
Hey.
Check the backside 4 baterey connector for baterey. All of them can fully touching surface.
Also change baterey. Check your charger. Hopes it can help
Old 10-06-2003, 22:20   #6 (permalink)
Member: 9584
Thanks Meter: 31
it is not the problem i checked the contacts battery and the charger.
Old 10-07-2003, 21:31   #7 (permalink)
proxy_gsm's Avatar
Member: 37349
Sonork: 100.1613413
Thanks Meter: 362
try by change P200 - 6pin's ic.
Old 10-07-2003, 22:14   #8 (permalink)
giorgi2002's Avatar
Member: 12524
Thanks Meter: 3
if any have pictures for sagem board i send repear solution
please send board pictures
[email protected]
Old 12-10-2003, 06:21   #9 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Your mail is not working !!! ([email protected])
Old 12-10-2003, 19:25   #10 (permalink)
Member: 12837
Thanks Meter: 2,740
Battery status unknow...
Hi2all
The problem occurrence while phone can't read battery ID resistor...
Possible cause is a:
bad battery ID resistor (change batt!);
bad wireing between batt connector and ASIC chip - for 9xx chip is SAGEM 18599662-5 ( check wires and resolder all connected components);
bad ASIC chip ( change/resolder ASIC);
Bad PCB - destroyed or some deformation(no solution!);
Old 03-30-2004, 09:15   #11 (permalink)
Member: 22505
Problem solved. (At Mx9xx. But i think at other models not big difference)
Battery Pin-out:
1- +Vbatt
2- -Vbatt (Gnd)
3- Indicator battery type
4- At board must be closed to GND
Beetwen pin 3 and 4 at battery set resistor. Resistance - battery type . I have two type - 7k5 and 13k. At board set capasitor.
Pin 3 through fuse or resistor (0 ohm) (white or black smd near pin 3 ) go to the 21 pin interface IC (18599662-5). The resistence beetwen pin 3 and GND on board must been 150 - 2500 ohm.
Chek all this values. And good luck.
P.S. At my board resistence beetwen pin 3 and GND go to Mohms. And after change interface IC all problems solved.
CloneFlashs / Ot310_BF3 -Unknown Lang Pack / Operator: Unknown- 3umer Multi-Box 0 10-07-2007 12:19
Myx5-battery status unknown valibuzauro ARM9 BASED M62 / M62+ 0 02-27-2005 10:32
MC926 battery unknown ataman Infineon C16X M51 & ARM7 M52 BASED 3 01-25-2004 19:32
sagem mc922 battery unknown OMBOSSMAN Infineon C16X M51 & ARM7 M52 BASED 4 12-01-2002 14:49
Help please - BATTERY UNKNOWN on Sagem 735 Chulitmg Infineon C16X M51 & ARM7 M52 BASED 3 10-30-2002 23:00
Page generated in 0.18466 seconds with 9 queries
