11-10-2009, 18:16 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | These TP's for ALL Flash IC species. Easy TP for W580/S500_Stage 2(TP2) Easy TP for K800/K810 Stage 1(TP1) |
11-11-2009, 00:30 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Nov 2007
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | Quote:
It is very difficult, and could damage the phone entirely | |
11-11-2009, 04:12 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 164786 Status: Offline Thanks Meter: 56 | You will be in small trouble only if there is glue between PCB and flash chip. If not, you can try to do like Siemens SL75 Test Point procedure(see in DBSS) and insert the wire a litle inclined(see the attached picture). You can try to use side tp too. It's not so hard to do. Identify what is your variant and test several times. Well, it's not recommended do it, but the chance you kill the flash chip is very very small. You can try to use a USB Microscope(Do you remember BB5 tp unlock?). It will help you a lot. Don't forget to post your result! Good luck! |
The Following User Says Thank You to paullovinicius For This Useful Post: |
How can I put the unlock code in BB Storm ? I canīt put the code | Grupo MovilFree | BlackBerry (RIM) | 3 | 02-23-2009 19:33 |
how can i know the mete.txt in the map | hkhorus | GPS devices , Navigators & Maps | 0 | 01-28-2009 11:18 |
how can i reach the test menu 4 g800 | hosam galal | QUALCOMM Models (3G) | 2 | 06-19-2008 19:36 |
how can i put the unlock code in my Siemmens ? | jolinga | Phone Unlocking Codes & Maps | 2 | 04-02-2004 00:03 |
How can i change the imei code in one alcatel 311?? | ragtap | BF, BG, TH, BHx Series | 2 | 01-22-2004 17:37 |
