11-10-2009, 23:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: philippines
Member: 45571 Status: Offline Thanks Meter: 45 | Dreambox repair K800 GDFS without TP |
11-11-2009, 04:00 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 164786 Status: Offline Thanks Meter: 56 | When you do "Security Bypass" procedure, your phone receives a pre-modified EROM that enables DreamBox features(unlock/repair/fullflash,etc). If you flash MAIN/RAW_FS with DreamBox or any other "normal" software, it will not touch on "DreamBox Modded EROM" installed in your phone and you can always use Security Bypass boot mode. You will lost the Security Bypass boot mode only with you update/repair EROM with non-tp solutions by others softwares, because it writes another patched EROM non compatible with DreamBox functionalities. Then, if you not use non-tp recover solutions you will always get a DreamBox "Security Bypass" compatible phone! Do you like the explanation? Then click "Thanks"! THANK YOU! |
The Following 4 Users Say Thank You to paullovinicius For This Useful Post: |
Guide :How to repair GDFS without tp and S1 unlock | Umair Rashid | SETool2 | 184 | 11-17-2013 12:35 |
Which is best box for sonyEricson for write gdfs without tp | syed tuqeer | The Market Feed Back | 3 | 07-15-2009 05:31 |
Repair GDFS Without TP CID50,51,52 & 53...... | dil_PAKISTANI | SETool2 | 11 | 11-18-2008 15:05 |
successfully unlock k800 cid53 without tp | jainmunda | Sony Ericsson | 2 | 05-10-2008 16:59 |
