Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 11-20-2009, 10:09   #1 (permalink)
Member: 1132412
Thanks Meter: 5
Mc60 need help
I am trying to flash mc60 siemens phone which came to me no power seems no hardware demages when i try to flash the phone it shows following errors
kindly some one guide me please.
--- Reading Info---------------------------------------------------------------
User selected phone MC60 using Test Point boot mode
Power On the phone ... OK
Hint : Please connect the probe with a button to testpoint
as shown in the description and wait.
Hint : Now the probe might be disconnected
Sending loader ... OK
Loading application ...OK
Testing RAM... OK
Error : #3140:00290253
[CFI Flash Chip Information]
JEDEC ID - 0000 ( 0000-0000 )
PRI Command Set - 0002 ( AMD / Fujitsu Standard )
PRI Ext. Offset - 0040
ALT Command Set - 0000 ( No Interface Specified )
ALT Ext. Offset - 0000
Minimum Vcc - 2.7 V
Maximum Vcc - 3.6 V
Minimum Vpp - chip has no Vpp pin
Maximum Vpp - chip has no Vpp pin
Typical Byte / Word Write Timeout - 128 mcs
Typical Full Buffer Write Timeout - 128 mcs
Typical Block Erase Timeout - 1024 ms
Typical Chip Erase Timeout - not supported
Maximum Byte / Word Write Timeout - 256 mcs
Maximum Full Buffer Write Timeout - 4096 mcs
Maximum Block Erase Timeout - 16384 ms
Maximum Chip Erase Timeout - not supported
Device Size - 1000000 (HEX) byte(s)
Bus Interface - 0002 ( x8 & x16 via BYTE# async. )
Maximum Multi-byte Write - 20 (HEX) byte(s)
Number of Erase Regions -
1) 0100 blocks of 010000 bytes
Flash Chip = ID : 00FA 0000 0000 0000 <unknown>
Error : #3140:00290219
Error : #3140:001D0390
Error : Invalid configuration please check model name
Error : #3140:001D0089
Error : #3140:002C017D
Error : Failed.
Old 11-23-2009, 06:29   #2 (permalink)
Member: 481368
Thanks Meter: 12
flash with software freiaufs2_st_no_xprot and ufs box
Old 11-23-2009, 16:56   #3 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Hello!
Looks like flash hardware damage.
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriousGold 66 08-27-2010 13:20
Can't access COM3 Loader of MC60, need your help!!!!!!! asdv E-Gold Based Phones 12 07-16-2005 12:25
Mc60 Need To Decustomize Help gsm-tech1385 E-Gold Based Phones 3 06-12-2005 17:03
MC60 TestPoint to deep,need help cole Siemens Hardware Repair Area 3 02-06-2005 21:36
Unlocking MC60 Problems!!! need help Scorpion_Blood E-Gold Based Phones 14 01-09-2004 00:10
Page generated in 0.13484 seconds with 9 queries
