11-20-2009, 10:09 | #1 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1132412 Status: Offline Thanks Meter: 5 | Mc60 need help kindly some one guide me please. --- Reading Info--------------------------------------------------------------- User selected phone MC60 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Error : #3140:00290253 [CFI Flash Chip Information] JEDEC ID - 0000 ( 0000-0000 ) PRI Command Set - 0002 ( AMD / Fujitsu Standard ) PRI Ext. Offset - 0040 ALT Command Set - 0000 ( No Interface Specified ) ALT Ext. Offset - 0000 Minimum Vcc - 2.7 V Maximum Vcc - 3.6 V Minimum Vpp - chip has no Vpp pin Maximum Vpp - chip has no Vpp pin Typical Byte / Word Write Timeout - 128 mcs Typical Full Buffer Write Timeout - 128 mcs Typical Block Erase Timeout - 1024 ms Typical Chip Erase Timeout - not supported Maximum Byte / Word Write Timeout - 256 mcs Maximum Full Buffer Write Timeout - 4096 mcs Maximum Block Erase Timeout - 16384 ms Maximum Chip Erase Timeout - not supported Device Size - 1000000 (HEX) byte(s) Bus Interface - 0002 ( x8 & x16 via BYTE# async. ) Maximum Multi-byte Write - 20 (HEX) byte(s) Number of Erase Regions - 1) 0100 blocks of 010000 bytes Flash Chip = ID : 00FA 0000 0000 0000 <unknown> Error : #3140:00290219 Error : #3140:001D0390 Error : Invalid configuration please check model name Error : #3140:001D0089 Error : #3140:002C017D Error : Failed. |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
Can't access COM3 Loader of MC60, need your help!!!!!!! | asdv | E-Gold Based Phones | 12 | 07-16-2005 12:25 |
Mc60 Need To Decustomize Help | gsm-tech1385 | E-Gold Based Phones | 3 | 06-12-2005 17:03 |
MC60 TestPoint to deep,need help | cole | Siemens Hardware Repair Area | 3 | 02-06-2005 21:36 |
Unlocking MC60 Problems!!! need help | Scorpion_Blood | E-Gold Based Phones | 14 | 01-09-2004 00:10 |
