05-02-2008, 03:27 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: always here Age: 31
Member: 701656 Status: Offline Sonork: 100.1605121 Thanks Meter: 111 | What Is This User selected phone W200 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. and phone not. power |
05-02-2008, 04:18 | #7 (permalink) | |
Member: 701656 Status: Offline Sonork: 100.1605121 Thanks Meter: 111 | Quote:
v0.914028/UNI CARD SERIAL: 00055218 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35540501509210 CERT:RED FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35540601471892 Model:W200a MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package:AMERICA_2 CDA article: CDA102738/310 CDA version: R3A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4GB001_CXC1250719_GENERIC_ME" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed: 3 secs. .... what should make | |
05-02-2008, 04:45 | #8 (permalink) |
Member: 701656 Status: Offline Sonork: 100.1605121 Thanks Meter: 111 | flashe the phone with setool box, but continue similar... its is the "read phone info" in normal mode with dream box. --- Reading Info--------------------------------------------------------------- User selected phone W200 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done. it is the log of operations --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. and phone not power on, not be make.. help me and light of infrared blink... |
05-02-2008, 06:43 | #9 (permalink) | ||
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
BR | ||
05-03-2008, 15:56 | #12 (permalink) |
Member: 701656 Status: Offline Sonork: 100.1605121 Thanks Meter: 111 | bro and attempted write other GDFS and unlock, but sample the same message. Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. |
05-03-2008, 16:05 | #13 (permalink) |
Banned Join Date: May 2006 Location: United Kingdom
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | I Had The Same Problem I Tried To Repair It With Dream Box But No Success Then I Changed The Flash Ic And Did It If Any Method Should Be Discussed |
05-04-2008, 03:14 | #15 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 164786 Status: Offline Thanks Meter: 56 | No... maybe you wrote a GDFS or FULLFLASH from a "DreamBox unlocked" phone in a non "Security Bypassed" phone. Your EROM is not "DreamBox modified EROM", then it checks security areas at boot. DreamBox unlock remove this areas, because that Dreambox modified EROM that is writen in "Stage 1/2" don't verify security areas, but original EROM checks(phone not entered in security bypass). Can you boot pressing C and using DCU-60? If yes, flash and customize it by SETOOL using DCU-60 and retry the "Security Bypass" procedure. If no, you need to restore original GDFS. Try to select "Normal" boot mode to restore a previously made GDFS backup from this phone. If you made backup using SETOOL, restore with it. But if you made backup using DreamBox and can't restore it, you will need another W300 CID52, but this "Security Bypassed". Backup GDFS from W300 working phone using SETOOL. Write the DB GDFS backup of dead phone in good security bypassed phone using security bypass mode. after, backup GDFS from "good phone" (that now have dead phone GDFS) with SETOOL and restore this GDFS to dead phone. Your phone will live again, but you need to flash MAIN+RAW_FS using DCU-60 by SETOOL to do Security Bypass on DreamBox. Don't forget to restore GDFS backuped from the good phone using SETOOL. If you don't have any backup from GDFS, you need wait for a new update. Procedure tested by me and works good. |
SE w395 i want to unlock.....what is this problem? | adamsquall | Universalbox | 2 | 03-29-2010 14:11 |
What is this, what effect | 1122001122 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-29-2010 09:18 |
what is this ? What are you trying to do?UB TEAM! HELP ME !!!! | lidergsm1 | Universalbox | 1 | 04-14-2009 18:36 |
what is this sc team ware is chi mei option and ware is imode option | rajabrotherscom | Smart-Clip | 14 | 02-16-2007 00:25 |
