06-03-2008, 00:00 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: south america Age: 46
Member: 10561 Status: Offline Thanks Meter: 8 | s500 red blink but canīt coonect see the log: -- Reading Info--------------------------------------------------------------- User selected phone S500 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Error : Failed. Nothing more. How can i connect? in this state I have one more w580 br. Malacatonche |
06-03-2008, 03:28 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | please check and clean your contacts from cable to phone.clean the interface where we insert the cable so it will have good contact.also check that you connect the right wire to its positive terminal. |
06-03-2008, 12:51 | #3 (permalink) |
Member: 10561 Status: Offline Thanks Meter: 8 | all is ok, the phone never was selled, I made others and all okey but i have problem in this two phones, both with the same error.. any other sugestion? br |
06-04-2008, 04:00 | #5 (permalink) |
Member: 10561 Status: Offline Thanks Meter: 8 | I canīt do anytest point, as U can see in my first post. I donīt have any chance of do tp or other process becouse the soft give error inmediatly. br malacatonche |
06-04-2008, 18:10 | #10 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | same problem with a k810 and right now with a k790, red blink, dont connect at all: http:///vbb/showth...11#post3372011 somebody face and succed in solution form this problem? Code: Info--------------------------------------------------------------- [04/06/2008 08:20:02] User selected phone K790 using Test Point boot mode [04/06/2008 08:20:02] 1) Turn OFF the phone. [04/06/2008 08:20:02] 2) Connect the phone to DreamBox cable. [04/06/2008 08:20:10] Warning : Aborted by user. [04/06/2008 08:20:10] [04/06/2008 08:20:37] --- Reading Info--------------------------------------------------------------- [04/06/2008 08:20:37] User selected phone K790 using Normal boot mode [04/06/2008 08:20:37] 1) Turn OFF the phone. [04/06/2008 08:20:37] 2) Connect the phone to DreamBox cable. [04/06/2008 08:20:44] try with other and read ok, i checked pins, right possitive, box drivers, etc etc all goes fine with another phone. B.R |
06-04-2008, 21:19 | #11 (permalink) | ||
No Life Poster Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks Meter: 97 | @renzox the problem with those phones is on fast port, but this problem is not the same: Quote:
i don't know why? but woks | ||
06-04-2008, 23:22 | #12 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | [quote=malacatonche;3367011]Hi, I have a brand new, S500 with redblink problem, but i canīt connect see the log: -- Reading Info--------------------------------------------------------------- User selected phone S500 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Error : Failed. hiting on flash ic then chech battri connector dream box is the best father |
06-05-2008, 00:04 | #13 (permalink) | |
Member: 598854 Status: Offline Thanks Meter: 141 | Quote:
B.R | |
06-05-2008, 00:08 | #15 (permalink) |
Member: 10561 Status: Offline Thanks Meter: 8 | me too, two ports, two pcs, and canīt connect, and almost brand new phones. the problem isnīt the flash chip becouse I can flash with other tools Br. |
W830 Red Blink But GDFS Normal | Belato | SETool2 | 4 | 03-02-2010 19:59 |
s500 red blinking | hrki | KULANKENDI Server | 2 | 02-09-2009 17:09 |
K800 Red Blink but cant attatch | Softway | DreamBox | 11 | 09-07-2008 10:16 |
W580 repair red blinking but.... | c_ahmad79 | DreamBox | 10 | 05-13-2008 16:32 |
k300i dead, only red blinking but only without baterry | NEON-GSM | Sony Ericsson Hardware Repair | 3 | 09-05-2005 14:12 |
