05-06-2008, 19:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | W580 repair red blinking but.... i have one question i had repair alot of gdfs with dream box.. but today i had repair w580 gdfs but after that i am trap in a problem i need to change the imei of this mobile.. but now i cant change it coz se-tool and fg cant change the imei coz some thing wrong with mobile's certifactes mobile is working fine but i cant chagne imei dream team plz add imei change coz its impossible now to change imei of mobile which is repaird with dream box.. dream team can you explain wot is the problem exactly and how can i solve my problem waiting for the kind reply thanks |
05-06-2008, 22:08 | #2 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: T.me/unlockarena
Member: 446040 Status: Offline Thanks Meter: 1,065 | hi, write this as script with setool , then perform change IMEI on your phone . Quote:
05-07-2008, 13:11 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Hi c_ahmad79! We don't plan to support a change of IMEI for now. We can give you only a solution for compatibility phone with SE Tool after operations with DreamBox SE. But for this we need some GDFS file from db2020 and db2012. Read GDFS using Test Point without entering "Security Bypass" and send it to us. We will research it and give you right solution. |
05-07-2008, 13:45 | #4 (permalink) |
Member: 446040 Status: Offline Thanks Meter: 1,065 | hi , the script i wrote on the post 2nd , is the exactly what you wanna research for that ,after write that Setool can recognize the phone on usb . |
05-07-2008, 14:12 | #5 (permalink) | |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | Quote:
Nb.. DBSE + Setool = more powered...is the best for SE.... | |
05-13-2008, 14:14 | #10 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | sorry ... this one ...? coz...my ic is same this one.... but while connecting to the TP the software shows different one.... little bit confusion... please clear this... |
05-13-2008, 16:32 | #11 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | no help.... anyway i did GDFS repair success.... thanks to DreamSE team.... Code: -- Security Bypass------------------------------------------------------------ User selected phone W580 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352430-02-272066-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352430-02-272066-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380AE6025206C42 Finalizing ... Stage 2 completed succesfully Done. --- Loading GDFS file---------------------------------------------------------- Loading "D:\DreamSE\GDFS\W580_GDFS_Totaltimer reseted\W580_GDFS_Totaltimer reseted.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone W580 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352430-02-272066-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380AE6025206C42 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W580 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352430-02-272066-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380AE6025206C42 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. --- Reading Info--------------------------------------------------------------- User selected phone W580 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352430-02-272066-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done |
<<<<Succsessfully repair red blink w580 with se-tool>>>> | Harkishan singh | SETool2 | 7 | 03-22-2010 10:08 |
s500 red blink but canīt coonect | malacatonche | DreamBox | 26 | 04-03-2009 18:30 |
K510 whitescreen repair success with REPAIR RED BLINK buton | firmanbali | Universalbox | 1 | 10-13-2008 13:49 |
K800 Red Blink but cant attatch | Softway | DreamBox | 11 | 09-07-2008 10:16 |
k300i dead, only red blinking but only without baterry | NEON-GSM | Sony Ericsson Hardware Repair | 3 | 09-05-2005 14:12 |
