Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 12-02-2005, 18:18   #1 (permalink)
Member: 203783
Thanks Meter: 7
K750i --> W800i & IMEI
I have a k750i at the moment but it needs an IMEI change.
If i wanted to change IMEI and upgrade to w800i would i just have to change the imei number in SEMC then flash the phone with the IMEI patched w800i flashfiles or is there anything else i would need to do?
Thanks a lot in advance!, Andy
Old 12-02-2005, 21:55   #2 (permalink)
intouchce's Avatar
Member: 105154
Thanks Meter: 2
changing K750 to w800
Hi,
Not that you are going to, but IF someone wanted to change am IMIE they would would use the unlock tab, tick the "change imie" and enter new imie. click "Do selected job"
once that is done you have to flash the main_imie and fs flash files to the phone using the "flash ARM" tab. remember to use the K750i flash files.
Once that's done flash the w800, main and fs flash files. upgrading a K750 to w800 is easy. just flash the w800 files to the phone.
cheers
Old 12-02-2005, 22:03   #3 (permalink)
Member: 203783
Thanks Meter: 7
But wouldn't flashing the w800 files overwrite the k750i main_IMEI so the OTP imei would be active again rather than the flash IMEI?
Old 12-02-2005, 22:03   #4 (permalink)
maxijazz's Avatar
Member: 93787
Sonork: 1646397
Thanks Meter: 9
once you change the imei,you always have to use patched flash files.so try to flash the phone W800 patched files,which are on support.no worries if the phones doesnt power on,just flash it back to K750 and will be ok.
br;
maxijazz
Old 12-02-2005, 22:06   #5 (permalink)
Member: 203783
Thanks Meter: 7
That's what i thought! Worth a try.. as you say, i can always flash the k750i files and undo any mistakes.... thanks a lot
Old 12-02-2005, 22:38   #6 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
Use the w800 patched flash and fs file and all will be ok
Old 12-03-2005, 01:07   #7 (permalink)
cairnquay's Avatar
Member: 64893
Thanks Meter: 221
K750i To W800i
Definately does work as i`ve tested this before
Old 12-03-2005, 12:08   #8 (permalink)
Member: 203783
Thanks Meter: 7
Thanks everyone for your quick responses! i want the looks of a k750i and the features of the w800i so that's absolutely perfect! thanks again, Andy
Old 03-25-2006, 17:37   #9 (permalink)
4ly
Crazy Poster
Member: 172541
Thanks Meter: 4
Ellloo
i have change IMEI wid cruiser for w800i it went throug oke but ven i cheack fone Imei wid *#06# it cumz up with 18 digit of Imei any bdy have any idea how to put only 14 digit one
thankz
Old 05-21-2006, 21:43   #10 (permalink)
Registered User
Member: 44779
Thanks Meter: 4
I have a D750@K750 with R1BC002. As I know its CID49 but the soft reads out Flash CID: 36. How?
If I want to change IMEI on this phone can I use W800_R1AA008_ZONE1_STANDARD_IMEI and the good FS to convert it to W800 and change imei?
It's not problem to flash it with lower fw version?
Thanks!
Old 05-22-2006, 11:28   #11 (permalink)
Member: 176776
Thanks Meter: 5
Thanks!
R1BC002 is used on CID49 phones but can be used on CID36 phones too .
if the software reads out Flash CID: 36 then the phone is IS CID36 - no doubt about it .
you will have to use these files you mention above .there is no problem using lower version if you have a cid36 phone.
W800i & K750i DEAD! Please help! UnlockBR Cruiser Suite 12 07-27-2006 15:22
w800i & k750i bluetooth hanging?? tsarkh HWK 7 04-28-2006 22:54
K750i to W800i + IMEI Change...with USB Smart Mobile-madman SonyEricsson (USB-Smart) 0 02-03-2006 06:39
K750i --> W800i Can I use R1L instead of R1K tgfrulez TOTAL MultiServer 5 09-23-2005 00:59
K750i -> W800i problem .. need flash color RED! -Wickings- TOTAL MultiServer 2 08-19-2005 08:16
Page generated in 0.20189 seconds with 9 queries
