Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 04-28-2006, 16:34   #16 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
thanks for the info Randy_D4, this unit has been a pain in the neck
Old 04-29-2006, 14:44   #17 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
I have tried to flash a dead J200i but didnt succeed. If I flash the language file it gives "error 00AD29" at 100% but if I flash the EEPROM file it is flashed successfully n I can also remake the CRC successfully but this is of no use. The phone is still dead after all this. Plz help...
Old 04-29-2006, 15:46   #18 (permalink)
Member: 4891
Thanks Meter: 9
Thank you,i have repaired one J200i by you solution.
JivkoBg.
Old 04-30-2006, 17:18   #19 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
I have tried this method but it didnt work for me... Plz can someone advice me on this... Thnx in advance.
Old 04-30-2006, 18:41   #20 (permalink)
randy_d4's Avatar
Member: 71246
Thanks Meter: 40
As I see U tell us that U have flashed language file not Repair full flash from support.
Flash him and then remake CRC.Post result
Old 05-01-2006, 07:14   #21 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
@randy_d4, I m sorry, couldnt locate the repair file on the support. I have downloaded it now. I will flash it n will post the results. Thnx for the help mate...
Old 05-01-2006, 10:08   #22 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
@randy_d4, thnx for the solution. Yes, it did work the way u have asked to do. The phone is alive again. Thnx mate...
Old 05-02-2006, 16:28   #23 (permalink)
cyklops's Avatar
Member: 54419
Originally Posted by zulea
4 bytes start address - little endian
4 bytes length - little endian
raw binary data
Best regards,
Zulea
sorry i dont know what you mean "little edian" if you inply im from india ? well then you wrong im from south africa , anway can you give a better explanation please
Old 05-02-2006, 17:00   #24 (permalink)
randy_d4's Avatar
Member: 71246
Thanks Meter: 40
HaHaHa
Man,I fall off my chair after reading your msg,if U dont know what's "little endian" so this job(converting files) isn't for U
short explanation about little endian :Method of storing data that places the least significant byte of multiple byte values at lower storage addresses. For example, a word stored in little endian format places the least significant byte at the lower address and the most significant byte at the next address.
Here more detailed information!!
I hope that U now understood that "little endian" have nothing to do with your coutryor your personality
BR ,no offence taken at all
PS:search in forum for "bin to arm convertor"and U will find all the answers for your questions
Old 05-02-2006, 19:18   #25 (permalink)
Member: 81268
Thanks Meter: 11
great work RANDY
br
Old 05-03-2006, 08:59   #26 (permalink)
cyklops's Avatar
Member: 54419
Originally Posted by randy_d4
HaHaHa
hehehe my opologies really
i dont understand that term lol sorry Zulea
Old 05-06-2006, 15:29   #27 (permalink)
zipzap_kill's Avatar
Member: 136173
Sonork: 108426:ind
Thanks Meter: 97
can we use j22 display in j 210
Old 05-12-2006, 15:11   #28 (permalink)
Member: 240612
Thanks Meter: 2
pls help with dead J200i
it was good working phone. i've tried simply to flash it with usb-smart and with flash from support J200_Config1_R2D.arm ...
Then it has been dead... only red blinkin, when charger is on...
I've tried this solution with J200_eeprom_fix.arm & J200_full_rep.arm but the phone still dead.. only red blinking on charge...
Maybe it is another right solution ????
PLS HLP !!!
Thx & sorry for my english
Old 05-12-2006, 21:21   #29 (permalink)
Member: 240612
Thanks Meter: 2
problem sloved... just flash it with full repair flash from Randy_D4 and make CRC.... but it ok ONLY like model Z200 !!!
Phone became alive
Old 05-25-2006, 18:16   #30 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
great job and veary good share mr randy
br
shami
need sollution for repair "phone startup failed" 6260 IkaMazini HWK 2 11-27-2007 08:08
W550i can't complete the phone after flash by SEMC tool 7.0........Please help superwing1248 SonyEricsson (USB-Smart) 7 04-13-2006 14:37
J210i killed by SEMC Tool FranekDolas MT-BOX 1 12-29-2005 00:57
Repair GD75 ****ed by Gold tools gwill Panasonic 1 12-03-2003 19:53
Page generated in 0.24496 seconds with 10 queries
