04-21-2006, 10:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | W900 no power : vibrates only I have one w900 I tried to unlock with test Point without knowing there was a new update, but it could not connect with TP. I then checked and found there there was a new update for Cid 49 w/O Tp I then closed the phone but it could not power up anymore and try again with the update to unlock but I am always geting error: Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED ERROR: 305015 I am having this error on what ever operation I do. Please assist me here BR keke |
05-05-2006, 11:00 | #5 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Please is there anyone that can help me here? This phone is driving me crazy. The TP has not been damaged. What is the reason for the error: 305015 Does this mean no one have had this problem? Please Zulea??????? BR keke |
05-19-2006, 08:37 | #6 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Would this phone be fixed Zulea where are you say something about this. Now version 8.4 but I am still having the same error message and not even a clue what could be the problem. keke |
06-09-2006, 08:28 | #8 (permalink) | |
Member: 12733 Status: Offline Thanks Meter: 26 | Quote:
Always stop at 5% and give this error : ERROR: 30223B. same ideas say battery problem but battery is fully charge and erom and main flashing without any problem. see atachment Please I need assistance Br keke | |
06-09-2006, 18:17 | #9 (permalink) |
No Life Poster Join Date: Aug 2005 Location: lebanon Age: 40
Member: 175671 Status: Offline Thanks Meter: 40 | for write fs you must use skip testpiont when flashing fs 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) FS file from FS directory - Not need to use Test Point on phone |
06-12-2006, 10:37 | #10 (permalink) | |
Thank you for your reply but Tried that also but it gives me error : 305014 BR keke | |
06-17-2006, 10:12 | #11 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Will it ever be possible to fix this phone please Zulea help me. The customer patience is going away Erom , main and eeprom can flash no problem but fs always stop at 5% I tried change test point to Tp2 and 3 will not even boot from those TP. Please rescue needed here. BR keke |
nokia 3310 not powering but vibrate only | gmps2003 | Nokia Hardware & Hardware Repair | 6 | 03-29-2013 21:14 |
5800 only vibrate no power on..... | vertex777 | Nokia Base Band 5 ( BB-5 ) | 65 | 01-21-2013 17:42 |
5800 only vibrate no power on..... | vertex777 | Nokia Hardware & Hardware Repair | 4 | 11-24-2011 08:23 |
lg kp 501 no power | lusomaco | LG Hardware Repair | 1 | 03-31-2010 12:44 |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
