06-28-2006, 18:30 | #1 (permalink) |
Insane Poster Join Date: Nov 2003
Member: 43244 Status: Offline Thanks Meter: 0 | Zulea w800i with different cid please help Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_BROWN OTP CID: 15 Phone IMEI: 04857555048575 Flash ID: 890D Operation succesfull Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 36 Phone IMEI: 35361255615521 Flash ID: 200D Operation succesfull |
06-30-2006, 15:01 | #6 (permalink) |
Crazy Poster Join Date: Sep 2005 Age: 44
Member: 178065 Status: Offline Thanks Meter: 0 | the problem is that usb smart responds to the phones as cid49 handsets, but somehow you did flash the fone but using wrong flash files. it is always better to flash the fone using appropriate flash files from support which is cid37 flash files, have u got another tool pls giv it a try cozz i had a same problem but got fixed. i can recommend if u try to write k750i cid37 erom so semc tool will recognize it as cid 37 then flash it as normally. pls let us know the results |
06-30-2006, 17:05 | #7 (permalink) | |
Member: 43244 Status: Offline Thanks Meter: 0 | Quote:
i have usb-smart only. can you tell me where can i get k750i cid37 erom? i couldn't find this in support. | |
07-04-2006, 13:05 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: INDIA
Member: 38103 Status: Offline Sonork: 100.100782 Thanks Meter: 165 | Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 356572005XXXXX Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R2T002_CXC1250075_EU_3_MI Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader Setup GDFS Loader Clear all SP locks Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Recover first flash part ERROR: CXC version not supported for recovery! Please flash MAIN, FS, Complete with any files from Support Area then make Unlock again to solve this error! ----- I think for unlocking.... one has to FLASH...AND it is a lengthy process in this age. So Zulea should implement some more restoral CXCs verz. |
Can i repair 3110c with imei 12345610654321 with MX KEY please help | ntothel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 10-10-2010 18:17 |
problem flashing with usb with any phone ! please help | johnlee007 | Universalbox | 17 | 01-09-2010 15:03 |
D750i @ K750i or W800i both white display please help!!! | oOXTCOo | SonyEricsson (USB-Smart) | 16 | 01-26-2009 09:50 |
W800i & K750i DEAD! Please help! | UnlockBR | Cruiser Suite | 12 | 07-27-2006 15:22 |
I have c30 with phone faliure, please help!!!!! | dollyb | NON Siemens Brand (ODM Phones) | 3 | 01-10-2002 03:02 |
