Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Motorola P2K (USB-Smart)
Old 07-31-2006, 01:44   #1 (permalink)
Member: 246621
Thanks Meter: 2
Dead V3 only keyboard lite up
Hello,
I have a dead V3 RAZR with only Keyboard lite up. What are the procedures to repair this phone. I know you have to repair the PDS but does that require testpoint?
Thanks!
Old 08-01-2006, 16:47   #2 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
Thanks Meter: 238
may i know if i m correct its the hardware error some sort of flex cabel problem.
NAEEM FAROOQUI.
Old 08-01-2006, 20:13   #3 (permalink)
ics_igrec_zet's Avatar
Member: 55427
Thanks Meter: 7
craxx99, what means "only Keyboard lite up"? this happens when you connect battery or when you power on the phone?
And second: you need to make TP for any flashing/repair opperation
BR, xyz
Old 08-01-2006, 20:41   #4 (permalink)
=CostyGSM='s Avatar
Member: 46387
Thanks Meter: 139
you dont need tp to flash moto v3 with rsd lite
Old 08-03-2006, 05:57   #5 (permalink)
amato's Avatar
Member: 111340
Thanks Meter: 8
V3 Dead
First check flash, if your phone is detected in flash mode for RSD lite , you can flash (fullflas) and try power on
If your phone no power on try write bootloader, maybe 07E0
and try to flash again
Good Lucky
Old 08-03-2006, 07:30   #6 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
For flashing motorola V3 for display problem in Smart clip an seniour poster gaved the what are the flash files to use in smart clip
R374_G_0E.42.07R_A
R374_G_0E.42.08R_A
R374_G_0E.42.0CR
Those files could be used as a solution for the handsets with nonworking internal display after flashing with 9CR version of flash file.)
But i dont have smart clip I am having only usb smart But i dont know which files to select to flash Can anyone know which files to select in usb smart for flashing V3 for display problem
Needed good advice
Old 08-07-2006, 11:58   #7 (permalink)
lafuente's Avatar
Member: 135097
Thanks Meter: 22
can you explain how i put boot loader if phone no power on? usb-smart no detect in power off mode
Old 08-07-2006, 11:59   #8 (permalink)
lafuente's Avatar
Member: 135097
Thanks Meter: 22
repair PDS AND full flash
Old 08-07-2006, 20:36   #9 (permalink)
=CostyGSM='s Avatar
Member: 46387
Thanks Meter: 139
Press *,# and power in the same time
Old 08-13-2006, 20:56   #10 (permalink)
lafuente's Avatar
Member: 135097
Thanks Meter: 22
Yes my friends this is right way.But i got one piece that go*+# power on for few seconds blink key-board and power off.USB no detect it.Who can help?
best regards
Old 08-14-2006, 06:55   #11 (permalink)
amato's Avatar
Member: 111340
Thanks Meter: 8
Arrow Motorola
<<<make a testpoint
check testpoint image , do testpoint and conect battery
Usb Smart detected motorola blank device
RAZR V3 dead screen - Only keypad lights up lmckdhu Smart-Clip 5 05-12-2009 09:36
D600 only keyboard litghts up. barrieb SWIFT Platform 2 01-10-2008 18:55
HELP V3 only keyboard lights up ticktock Smart-Clip 4 01-14-2006 17:58
Motorola v3 only light keyboard Carlazos Motorola P2k 12 01-12-2006 14:37
MOTOROLA V3 dead, only keyboard lights !!?? jode Motorola P2k 25 12-01-2005 19:27
Page generated in 0.20842 seconds with 9 queries
