10-04-2009, 09:43 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | f233 error connecting with phone, :: SOLVED ::: ERROR Connecting With Phone... phone in COM7, ON with no SIM tried 2.1.8 uo to 2.2.7 each and every single version plz help |
10-04-2009, 10:11 | #2 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | cable problem check it phone supported long time ago :: Polar Service Software :: ======================= Selected Lg ZTE-F233 ======================= - Phone Status ON - Use ZTE F230 USB Datacable Quote:
10-04-2009, 14:51 | #3 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | I am using original NEW cable, took it out of the box myself. Used as modem, PC sees it.. installed drivers, no problems. tried with f188 USB cable (same), tried with F230 ORIGINAL USB cable. change COM ports... (from COM52 to COM7), restarted pc. the only time I have needed the box that I sold last week.... Now I think I should have reinstalled ZTE drivers... anyway, I need ideas. "check cable" is not a good answer because I tested a few. Last edited by FullFLASHgSMPH; 10-05-2009 at 02:41. |
10-04-2009, 21:48 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | if ur phone is detected by ur computer then 100% drivers problems remove all drivers restart pc install again if problem same, then i suggest u to use a clean computer br <= The_Gorr => |
The Following User Says Thank You to The_Gorr For This Useful Post: |
10-05-2009, 02:41 | #5 (permalink) | ||
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
now USE NEW PC .... Post result... | ||
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
10-05-2009, 09:39 | #6 (permalink) | |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Quote:
wbr | |
10-11-2009, 09:13 | #8 (permalink) | |
I disable bluetooth | |
The Following User Says Thank You to hugmax For This Useful Post: |
KE970 problem to connect with polar box 2. ::: ANSWERED ::: | xcorp | PolarBox 3 | 6 | 08-12-2009 16:54 |
Error connecting with phone... ::: SOLVED ::: | Tatek | PolarBox 3 | 7 | 12-30-2008 16:50 |
709 error connecting to phone pl help | ruvanw1979 | NSPRO | 1 | 11-19-2007 06:22 |
709 sc error connecting to phone | ruvanw1979 | NSPRO | 0 | 11-17-2007 10:44 |
errors connecting any phones!!! | ionelka | FuriousGold | 1 | 10-12-2007 13:13 |
