Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 08-12-2009, 14:34   #1 (permalink)
Member: 1004434
Thanks Meter: 3
KE970 problem to connect with polar box 2. ::: ANSWERED :::
Dear PB Team,
While polar box said that "Please keep pressed power button until process finish" i press turn on and appear the following hardware to install driver (USB DEVICE):
Then i continue pressing turn on button and the phone fully turn on and the box do not recognise the phone, i have 2 ke970 with same problem.
What can i do?
Thanks very much!
Old 08-12-2009, 14:50   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
if phone is dead that can be damaged and can also damage box
if phone if ok, then check if polar work correctly with other phones
br
<= The_Gorr =>
Old 08-12-2009, 15:16   #3 (permalink)
Member: 1004434
Thanks Meter: 3
The phone is OK, and are two ke970.
The cable is also ok, because im unlocking other lg without problems. Im trying with lg KG800 USB cable, its correct one?
Any other solutions??
Thanks very much again!
Old 08-12-2009, 15:44   #4 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
No, that cable is not correct, you should use KG800 RJ45 not USB, this info from PolarBox Soft:
:: Polar Service Software ::
Selected Lg KE-970
- Phone Status OFF
- Use LG Kg 320 / Kg 800 Datacable
Luck!
Old 08-12-2009, 16:11   #5 (permalink)
Member: 1004434
Thanks Meter: 3
is same cable that ke500 and ks360??
Old 08-12-2009, 16:36   #6 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
It looks like KE500, same connector, but pinout is different.
Old 08-12-2009, 16:54   #7 (permalink)
rotelcam's Avatar
Member: 698210
Sonork: 100.1578921
Thanks Meter: 3,591
Always follow polar instructor in back window when u select model.
samsung s8000 is it possibel to unlock with polar box ?? ::: ANSWERED ::: [email protected] PolarBox 3 3 09-07-2009 11:58
E101 donīt power on after unlock with polar box 2 Mr_F10ch3 PolarBox 3 1 10-27-2008 08:13
Black Berry 8800 Flash with polar box 2? Service4Gsm.de PolarBox 3 4 10-22-2008 19:35
Canīt Unlock Sharp Phones With Polar Box 2 david69 PolarBox 3 2 10-16-2007 02:08
Page generated in 0.14422 seconds with 9 queries
