Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 12-17-2009, 22:45   #1 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
how to installe driver usb my501ci [ANSWERED]
hi i need how to installe usb driver sagem my501ci
the driver Drivers_SagemUSB.zip at suport can't work with me
Old 12-18-2009, 00:25   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,035
u need to solder rj45 rx tx gnd directly to phone
br
<= The_Gorr =>
Old 12-18-2009, 01:32   #3 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
use only rx DB9.9 and tx DB9.1 and gnd DB9.6
//\\toutou_gsm//\\
Old 12-18-2009, 18:38   #4 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
Connecting with Phone...
Sending First Loader......OK
Sending Second Loader......OK
Wait Response from Phone...
ERROR Phone Not Connected...
Old 12-18-2009, 18:43   #5 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
make sure the battery is fully charged,this is will be caused by low battery
also use latest version
test and report
luck
Old 12-18-2009, 19:40   #6 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
bro still same problem
battery full garged =ok
software v232 =ok
Old 12-18-2009, 19:51   #7 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
software v232 =ok
the latest version is 23.3 and not 23.2,also try to use any other interface instead of polarbox RJ45
try and post result
luck
Old 12-19-2009, 12:25   #8 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
still same bro
Old 12-19-2009, 12:37   #9 (permalink)
rotelcam's Avatar
Member: 698210
Sonork: 100.1578921
Thanks Meter: 3,591
Disconnect box and reboot Pc.
after reboot, connect only Polar box to pc usb port. dont use usb hurb.
connect phone to PB and start Polar suite.
make sure battery is full charge.
Also, u can try through comport.
Take care u touch no other key than power key in phone.
Good-luck
Regards
RotelcaM
still same bro
how to install a usb driver and java program into the nokia n95y+ zetel phone abanidd Java, iOS, Android, Symbian development 1 08-17-2009 05:08
How to install drivers for Option USB modem? James_S KULANKENDI Server 2 04-16-2008 13:22
how to instal driver m7021g pakfonelinks Scout 1 11-12-2007 13:01
FGB and KU970 - how to instal driver ? AndRe DCF-gsm FuriousGold 6 08-27-2007 09:17
How to install drivers hybrid.09 Cruiser Suite 2 03-17-2007 04:38
Page generated in 0.18600 seconds with 9 queries
