01-23-2007, 01:12 | #1 (permalink) |
Junior Member Join Date: May 2005 Age: 46
Member: 148630 Status: Offline Thanks Meter: 0 | E1 Unlock Sucess But Can't Power On! Last edited by hamcuala; 01-23-2007 at 05:55. |
01-24-2007, 04:06 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | same problem here with e1 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A02 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Save flash backup Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A02 Sending RAMDLD to handset Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0000 Sending RAMDLD to handset RAMDLD started ok in handset Write Bootcore zone on flash chip Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0200 Sending RAMDLD to handset RAMDLD started ok in handset Write PDS zone on flash chip Rebuild PDS checksums on handset Power down handset Rebuild PDS procedure completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0000 Sending RAMDLD to handset RAMDLD started ok in handset Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0200 Try to load backup file Sending RAMDLD to handset RAMDLD started ok in handset Recover handset from blank mode Handset recovered from blank mode Power down handset Easy Skip TP unlock finished ok but phone won't power on !!! and solution posted above is useless br |
01-25-2007, 02:34 | #8 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | BOOT LOADER 0A.02. SW_VERSION : R373_G_0E.30.44R PHONE CODE SIG ERROR : ( after pds repair or remove blank) i tried fullflashes on support like : R373_G_0E.30.6BR_PDS004_LP0039_DRM0101_JPJAVA_G_0E _E790_00_00_21I_SE7016AXXP106B_1FF.sbf R373_G_0E.30.44R_GSKKLGORGR01NA08E_Rogers_Firmware _1FF.shx plz urgent help br |
01-25-2007, 08:11 | #9 (permalink) |
Member: 148630 Status: Offline Thanks Meter: 0 | same here, i lost track with the firmware i've flashed(too many attemped) when *+#+power firmware have not change at all after flashed with different firmware verions, keypad light up for about a sec and that's all,but i can tell it's still charging when plugin the power, seem like it's still in sleeping mode(from my understanding)!! |
01-26-2007, 13:21 | #11 (permalink) |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | Please use GOT MOTO v0044 and make PDS repair procedure: http://forum.gsmhosting.com/vbb/showthread.php?t=368282 |
01-26-2007, 15:40 | #12 (permalink) | |
Junior Member Join Date: Mar 2006 Age: 51
Member: 246198 Status: Offline Thanks Meter: 0 | Quote:
Here is what I did: Set Blank Mode Repair PDS Remove Blank Mode The phone now displays bootloader 0A.05, it was 0A.02 previously. The phone nows turns on to the Motorola splash screen then shuts down. Do I need to reflash it? or will a testpoint fix this for me? | |
01-26-2007, 17:15 | #13 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | @letsgocellular now full flash and all should work (if got team really repaired their bug while they finally found it) br |
01-26-2007, 17:20 | #14 (permalink) | |
I couldn't wait, so I just fixed it by doing a pds repair and writing a full flash with my smartclip. But hopefully got fixed the bug. | |
n96 flashing sucess but not power on | adaki_vishal | HWK | 14 | 04-13-2010 13:58 |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
5210 Flashing is sucessful but cannot power on | eivoig | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 02-20-2005 13:41 |
Flashing GD68, but can't power on, GD67_fixed solution can't help | pc.net | Panasonic | 8 | 02-01-2004 11:55 |
T191 can charging, but can't power ON | jonwillow | Motorola Hardware Repair | 1 | 06-19-2002 16:17 |
