01-27-2007, 07:49 | #18 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 414704 Status: Offline Thanks Meter: 3 | Quote:
How can I flash it? I just flash with .shx, how can I flash .sbf with GOT??? Can you write a process for me? Thanks. Help. | |
01-27-2007, 15:10 | #20 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2004 Age: 45
Member: 85712 Status: Offline Thanks Meter: 131 | E1 not power On Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0000 Sending RAMDLD to handset RAMDLD started ok in handset Write Bootcore zone on flash chip Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0200 Sending RAMDLD to handset RAMDLD started ok in handset Write PDS zone on flash chip Rebuild PDS checksums on handset Write Bootcore zone on flash chip Power down handset Rebuild PDS procedure completed ok I have one problem with E1 Rocker After unlock used TP, Phone NOT Power On I now used version GOT 0044 After Repair PDS, Error on LCD : booat loader : 0A.05 SW Version: R373_G_xx.xx.xxy RBS HAB Error: 55 Please send me a solution urgent. |
01-27-2007, 17:18 | #21 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | ok here is a trick to unlock sucessfully e1 step by step just just unlockurs phone by easy tp then in repair tab click repair pds then urs phone will goes on blinking and boot versionwill be change to A.05 then flash the phone with this version R373_G_0E.30.44R_GSKKLGORGR01NA08E_Rogers_Firmware _1FF and every thing willbe ok i have sucessfully unlock this handset by this method and the phone is working perfect |
01-28-2007, 23:12 | #23 (permalink) | |
Member: 85712 Status: Offline Thanks Meter: 131 | Quote:
01-30-2007, 23:16 | #25 (permalink) |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | Use GOT MOTO v0045: http://forum.gsmhosting.com/vbb/showthread.php?t=368282 Select E1 model. Make PDS repair procedure. Flash with 1FF file. Now should work, also after PDS repair phone will have 0A02 bootloader. |
02-01-2007, 01:15 | #26 (permalink) |
Member: 414704 Status: Offline Thanks Meter: 3 | sorry, My E1 still not working My GOT is V0045, and my phone 0A02 R373_G_0E.30.44R And what I did is set blankmode repair pds remove blankmode flash R373_G_0E.30.44R_GSKKLGORGR01NA08E_Rogers_Firmware _1FF All procesure show complete sucessfully. But the phone is still dead. |
n96 flashing sucess but not power on | adaki_vishal | HWK | 14 | 04-13-2010 13:58 |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
5210 Flashing is sucessful but cannot power on | eivoig | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 02-20-2005 13:41 |
Flashing GD68, but can't power on, GD67_fixed solution can't help | pc.net | Panasonic | 8 | 02-01-2004 11:55 |
T191 can charging, but can't power ON | jonwillow | Motorola Hardware Repair | 1 | 06-19-2002 16:17 |
