01-19-2007, 20:46 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 44
Member: 142161 Status: Offline Thanks Meter: 8 | V190 R3517 MEM_MAP Blank HELPPP!!!! V190 R3517_G_0A.63.12R MEM_MAP Blank Service Reg' d GOT supporters I also need flash file for this model. Can I use the L6 R3517 for this model???? |
01-20-2007, 03:31 | #2 (permalink) |
Member: 142161 Status: Offline Thanks Meter: 8 | V190 GOT unlock problem Hi I was triying to unlock a v190, I select Easy TP procedure becouse phone had Bl 0.8D and after some procedures soft gets freezed so I closed it and make "Set Blanck Mode", ok, then I repaired pds, ok too, but when I make "Remove Blank Mode" software get freezed. Then I get , MEM_MAP Blank everytime I insert battery on the hone, what can I do? The phone is broked HELPPP - I try to recover the phone from "Blank Mode" an it gives me: Crtitial Error 80 40 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 08D0 Try to load backup file Sending RAMDLD to handset RAMDLD started ok in handset Recover handset from blank mode Error: 01060002 Error: 10040603 - I try to flash this V190 with flash file R3517 for L6 but give me this error. I make testpoint: Split input file in codegroups: Processed ok Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset Error: 01160004 Error: 01120003 Error: 01240004 Last edited by arans; 01-20-2007 at 11:45. |
01-20-2007, 14:48 | #3 (permalink) |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | You already made repair PDS, and phone now have boot 08D0 (repair PDS also write boot in phone), so you no more need to do Recover Blank. Just flash phone, with R3517 1FF GTC file. And you do NOT have to make testpoint for flashing! To get flash file, use SureGOT downloader. And yes, flash files are common for L2, L6, V190 (R3517). |
C390 - Prepare - error - MEM_MAP Blank and can't connect... | GSV | Smart-Clip | 4 | 07-18-2007 08:00 |
MEM_MAP Blank Service Req'd ----HELP---- | intouchce | Smart-Clip | 13 | 02-14-2007 13:32 |
V3i MEM_MAP Blank Service REQ'D | Phoneze | Smart-Clip | 1 | 02-06-2007 23:28 |
V190 - R3517 problem | sorinm | GOT Motorola | 2 | 01-26-2007 16:02 |
v190 r3517 got make on off | mrfixit | GOT Motorola | 0 | 01-22-2007 20:20 |
