01-25-2007, 08:03 | #1 (permalink) |
Freak Poster Join Date: Dec 1999 Location: 17 deg 49 min South
Member: 771 Status: Offline Thanks Meter: 9 | V3x...big problem...need assistant... Bootloader: 0.6.8.2 SW: R252211LD_U_85.97.F1P Its faild unlocking (PC stuck-freeze during unlocking) and now the phone is in Blank mode and I can't flash it-always error, but I can make "Repair PDS". I tried RSD Lite...but always "Faild". Unfortunatelly I don't have MSS4 or SC and i did't tried with these tools... I realy need help...thanks Establish connection to handset FLASH Interface established ok Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x017E2230 Write PDS zone on flash chip Rebuild PDS checksums on handset Write Bootcore zone on flash chip Power down handset Rebuild PDS procedure completed ok Split input file in codegroups: Processed 9 codegroups Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Error: 01120004 Error: 01210002 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Try to load backup file ERROR: Cannot find backup file |
01-25-2007, 08:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | When You plug cable in phone without boot mode ... is make sound ( connecting ) If Yes .... then just remove phone from blank mode ... then try to flash .... Hope help you Br |
01-25-2007, 09:47 | #3 (permalink) | |
Member: 771 Status: Offline Thanks Meter: 9 | Quote:
1. PC recognized the phone like: Motorola USB Device-Motorola Flash Interface-Blank Rainbow POG 2. GOT (or RSD Lite) also recognized the phone-"Connected Flash" 3. I can make "Rrepair PDS" with GOT 4.I can not flash the phone...with GOT I have message: Error: 01120004 Error: 01210002 ...with RSD Lite..."FAILD". 5. I can not make "Remove Blank Mode" with GOT: Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Try to load backup file ERROR: Cannot find backup file It means when my PC stuck I lost backup file...is it possible to use this file from another phone? 6. I tried "Set Blank Mode" with GOT but again no success: stablish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset Error: 01050001 Error: 30040201 And...what now...??? Thanks to all who want help.... | |
01-25-2007, 12:05 | #4 (permalink) |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | Fash one of this 2 files from the attachament (it depends if your phone have AMD or INTEL flash chip). Use Restore Bootcore button to flash this files. After that, flash your phone with 1FF file. And try to put GOT_MOTO.EXE in a folder on your PC and NOT on Dektop !! |
The Following User Says Thank You to gotsupport For This Useful Post: |
01-25-2007, 14:50 | #5 (permalink) | |
Thanks...gotsupport...all is OK...the phone is unlocked and in working condition....but....I am very confused...I don't know anything in this moment! What heppened? 1. I made Restore Bootcore with your backup file for AMD flash chip...operation success...but the phone was still dead...in flash mode (Blank mode)...I tried Repair PDS...success...but no help...tried to flash...errors... 2. I made Restore Bootcore with your backupe file for Intel flash chip...operation success...but the phone was still dead...always in flash mode (Blank mode)...Repair PDS...OK...but flash...errors... 3. So I tried few times same operations...disconnect the phone from PC...conect the phone...Restore..Repair...conect...disconect...and .......in one moment the phone switched on in my hand..... I chacked...all is OK...the phone is unlocked and working properly... I know these are funny and stupid....the fact is I didn't flash the phone....I was very tired with this phone...so I didn't remember row what I was doing...but maybe you know now what was problem with this stupid phone and stupid unlocker ( me ! ) .... Thanks very much... | |
The Following User Says Thank You to plruzza For This Useful Post: |
01-25-2007, 15:02 | #6 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 44
Member: 89661 Status: Offline Thanks Meter: 35 | Normally he dose't need to flash the phone, repeating unlock would have solve this problem at the first time. And I think it should still solve it. I got same problem with usbsmart and was solved when I repeated unlock process. |
01-25-2007, 15:57 | #7 (permalink) | |
Yes i remember I tried to do unlocking proces but it didn't help in this case.... Story is that the phone didn't switching on after faild during unlocking....if I put it in flash mode with "*" and "#" and power it was showing some critical error on the screen, and later after Repair PDS with GOT didn't show anything on the screen and it was always in flash mode...imidiately after battery is atached PC recognized Motorola USB Device....Conected flash But "miracle" (GOT= G O D ) repaired this phone.... | |
06-14-2008, 17:50 | #9 (permalink) |
Junior Member Join Date: Mar 2008 Age: 31
Member: 729628 Status: Offline Thanks Meter: 0 | Hey, I need to repair 2 V3x phones but I can't download the attached files. The attachments are not working, nowhere on this site. Can anyone upload them on RapidShare instead pls? |
06-17-2008, 08:33 | #10 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | there are 2 type of processors in this model check that out http://maxupload.com/86A38979 AMD http://maxupload.com/01E575E6 intel NAEEM FAROOQUI. |
The Following User Says Thank You to nnaeem11 For This Useful Post: |
Nokia 7600. Big problem, need help! | utbracket | Nokia Hardware & Hardware Repair | 11 | 01-05-2009 11:32 |
v3x big problem{bug in software} | pava | Ultima Box Light | 2 | 03-09-2007 15:26 |
703shf big big problem. need help | Siemens man | Sharp 3G (USB-Smart) | 13 | 08-08-2006 23:54 |
R380 big problem. need urgent help. | IceKiller ZLIN | Old Ericsson Phones & Sony Phones | 2 | 10-05-2002 17:28 |
Sagem 835 fm big Problem!! need help, please! | Elgravi | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-21-2001 00:19 |
