allGSMunlock MultiOnline Remote Server 20 |
11-13-2008, 12:35 | #1 (permalink) |
Banned Join Date: May 2006 Location: United Kingdom
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | Having problem with the preivous jobs i have fresh windows installed and after i installed 5.4 and i cant see the previous submission or history at all i have submitted for tmobile sidekick and i cant see it anymore in my cliet as all new submission i can see and working fine thanks |
11-15-2008, 02:44 | #2 (permalink) |
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | i was expecting a reply from artix as he's not coming on msn so thought he'll reply here. I am having problem retrieving previous submissions and history may be its but in 5.4 or i am doing something wrong waiting for your reply thanks |
11-15-2008, 06:43 | #3 (permalink) | |
Product Manager Join Date: Apr 2007
Member: 488825 Status: Offline Thanks Meter: 365 | Quote:
BR. Masterunlocking | |
11-16-2008, 00:31 | #5 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 669827 Status: Offline Sonork: 1576281 Thanks Meter: 3,099 | Just do this sir, it HAS to work, there is no other way: Reset your activation code: Support -> Personal Info -> Show -> Reset Activation, make sure you use the code you received in your e-mail the first time your account was created. Then the client will ask to restart - do this. Go in the installation folder of the client and delete all the files in the FINISHED JOBS folder, here: /program files/allgsmunlock/finished jobs After you have done this, select HISTORY from the menu in the client then click SHOW (make sure you also select INVALIDS at the bottom of the history window). You will see a list of ticket files, you need to click download for each of them and all your completed jobs will be there. If that doesn't work, then you are either not doing it correctly or you are using an incorrect activation code. Also, make sure you have selected INVALIDS at the bottom of the STATUS/HISTORY windows. |
""Samsung SGH R220 having problem with the Network"" | rajeevpchandran | Samsung Hardware Repair | 0 | 07-08-2008 06:09 |
having problems with the univerasl simlock remover :( | whitenight | Universal GSM Software | 0 | 05-28-2006 22:46 |
sorry to be a drag.. but i still have problems with the box | ovallito | Universalbox | 1 | 12-20-2005 16:02 |
New GD55's have problems with the Russian flash IMEI Changes to A1000000000051 >> | STB Trading | Panasonic | 69 | 08-07-2005 05:52 |
Have problem with the C350 USA T-Mobile | wiky | Smart-Clip | 4 | 08-08-2004 22:04 |
