allGSMunlock MultiOnline Remote Server 20 |
01-06-2008, 18:48 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 46
Member: 125606 Status: Offline Thanks Meter: 0 | What happened? Was getting correct K1 unlock codes and then it stopped! ================================= Unlock by imei MOTOROLA Free K1 IMEI: 35920601002XXXX ============================= Unlock Code: 7748536768904170 ================================= Now, 2 codes, both are 8 digits and do not work! ================================= Unlock by imei MOTOROLA K1 IMEI: 35920601018XXXX ===================== Unlock Code: 81700106 ===================== Wap Code: 79606069 ===================== CREDIT: 5 ================================= Unlock by imei MOTOROLA K1 IMEI: 35920601042XXXX ===================== Unlock Code: 38176036 ===================== CREDIT: 5 ================================= Could you please fix the problem and send me the correct 16 digit unlock code? Thanks! |
01-06-2008, 21:11 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Sonork: 100.1575111
Member: 522338 Status: Offline Sonork: 100.1575111 Thanks Meter: 250 | No friend, here is nothing wrong: Is special script, when MOTOROLA have code with 16 they is sended in server, when codes is with 8 digits in server is send 8 digits ! WBR, allGSMunlock |
01-07-2008, 04:40 | #3 (permalink) |
Member: 125606 Status: Offline Thanks Meter: 0 | I have paid a total of 10 credits for these two IMEI. You know that I have even spent 9 credits on a single Motorola code in the past if I needed it in a rush and the Motorola server was closed for the day. I need help or I would like a refund. Right now, why have I spent 10 credits? You have provided two codes that do not work. So what do I get out of these 10 credits? Talk to your provider and find out why it was working previously and then it stopped now. They must know! Look at my IMEI: 35920601002XXXX. It received the correct unlock code! Ask your provider how they were able to get that code. Also notice that the IMEI is very similar to the other two K1s. So I get a working 16 digit code. And then 2 fake 8 digit codes. If there is an alternative method to enter the code in the phone, please provide it. I'm sure there is a solution as you have provided 55 working unlock codes to me. Maybe you should cancel the Motorola service for K1 phones if you cannot provide the correct information? Please let me know. |
01-07-2008, 06:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | you just have to input first 8 digits when subsidy code is asked by the phone, i have unlock many motorolas with 8 digits codes, luck |
01-07-2008, 17:10 | #5 (permalink) | ||
Member: 125606 Status: Offline Thanks Meter: 0 | Quote:
The new Motorola K1 phones require 16 digits unlock code. You can see how that one worked because it had 16 digits. Here is some more links: http:///vbb/showthread.php?t=477606 http:///vbb/showthread.php?t=478909 http:///vbb/showthread.php?t=479455 Maybe I can receive a screenshot from the K1 that received the correct unlock code and then the screenshot from the wrong codes. I will try to see what is the difference in the result. I know it must be an error with the Motorola server or script as the IMEI of the phones are too similar. If the IMEI of the phones were very different, then I'd understand there is a problem. But you can tell from the IMEI that these phones are from the same batch, so why did 1 phone receive the proper 16 digit unlock code and then 2 other phones received incorrect, non-working codes? | ||
A65:when I try to turn it on it shows blue screen and bip and then it turns off by it | beneto | DreamBox | 3 | 03-04-2010 13:38 |
k1 flashed successfully and then poof! gone | Vancellular | Smart-Clip | 3 | 09-27-2007 08:40 |
A65,it turns on,blue sreen and then it turns off... :( | SicilianBoy | DreamBox | 5 | 10-28-2006 10:36 |
c65 dial pin and then it goes off | noone0 | Siemens Hardware Repair Area | 0 | 02-24-2006 23:44 |
Can someone get me the unlock code for my T-Mobile Sharp TM150? I will pay for it! | slick_b_69 | Sharp | 1 | 01-30-2005 18:03 |
