12-22-2007, 11:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Problem Flashing with Scout Software i've tried to unlock one V3xx with Smart Clip it unlocks OOk, but after that it only boot in boot mode so i try to flash it with scout software v1.03 but checksum mismatch error i got and fone still booting in boot mode only here is the log from scout flasher software. Flashing phone "S Flash Argon - R26111LD_U_96.71.95R" with firmware "C:\Documents and Settings\Ethio Mobile\Desktop\R26111LD_U_96.71.95R_LP0003_DRM0011 _VSTU_207_010D_JPNA_R26111IZRGBLCIN_21_USIZRGBLCIN USR26111083_1FF.pcf"... Preparing firmware image... Loading RAM downloader for bootloader... Erasing flash memory... Erase completed! Flashing code group 0... Code group 0 flashed Flashing code group 1... Code group 1 flashed Flashing code group 2... Code group 2 flashed Flashing code group 3... Code group 3 flashed Flashing code group 4... Code group 4 flashed Flashing code group 7... Code group 7 flashed Flashing code group 15... Code group 15 flashed Flashing code group 17... Code group 17 flashed Flashing code group 18... Code group 18 flashed Verifying checksums... Code group 0 checksums match Error verifying code group 1 - checksums mismatch Error verifying code group 2 - checksums mismatch Error verifying code group 3 - checksums mismatch Error verifying code group 4 - checksums mismatch Error verifying code group 15 - checksums mismatch Error verifying code group 17 - checksums mismatch Code group 18 checksums match Flash failed Flash completed with error/warning: Flash library error 49 what should i do know to recover my fone??? Take Care ENJOY |
12-24-2007, 12:59 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | The fact is that you have done something wrong during unlocking process because the phone is in boot mode now. Where is your log of unlocking process? The problem can be located at hardware software level. So log file would help to understand the reason of your issue. Was temporary backup created during unlocking? Now I can advice you to flash the phone with some higher firmware version of pcf file. For example R26111LD_U_96.80.51R |
12-24-2007, 13:39 | #3 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
Take Care ENJOY | |
12-24-2007, 13:45 | #4 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | here i'm attaching a screen shot before flashing with RSlite you can compare the file i used and the software already in fone. Take Care ENJOY |
Clarification ... Can I use S-Card with SCOUT Software ...??? | JammerTwo | Scout | 5 | 06-18-2008 16:09 |
Clarification ... Can I use S-Card with SCOUT Software ...??? | beerfoote1 | Smart-Clip | 1 | 06-18-2008 16:04 |
F3 can't be flashed with SCout software | Bmt_HR | Scout | 15 | 10-26-2007 10:51 |
C261 Successfully Flashed via SCout Software | zLer | Scout | 6 | 10-13-2007 12:59 |
SCard is compatible with SCout software...? | kashi4gul | Smart-Clip | 2 | 08-09-2007 05:34 |
