07-16-2007, 10:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Spinning on my OWN Orbit
Member: 5358 Status: Offline Thanks Meter: 211 | Correct procedure of Using Multi box After buying from reseller download the drivers and registration tool. Fill up the form correctly including the reseller name: after registration completed you can received in your email an account for support area download the latest update tool just to update your box or else you will wait for another day... If unsuccessful update of box you can contact directly to support chat:::: of multibox at support area( if online) if offline take a good sleep and wait until it becomes online... Just read all of this and Im sure It will helps a lot for you! Correct procedure of Unlocking Mitsubishi 342i 1. build a cable use samsung 18 pin cable need: 1 pc 2k resistor 1 pc 180 k resistor 2. Follow correctly this cable schematics 3. Turn on phone (m342i) insert cable and you will see this 4. Hold * and press 5472 and phone go to test mode and then press unlock mitsubishi tool.. phone unlock after.... |
how to slove the problam of the chines phone useing multi-box | GSM_N4H | Multi-Box | 25 | 01-24-2008 17:25 |
Procedure of opearting Furious Box ? | Sir_GsM | FuriouS II | 6 | 10-17-2006 14:22 |
Are U Facing Problem While Using Multi-box Vote Here | chiragp | Multi-Box | 4 | 08-20-2006 21:40 |
w900i correct procedure of flash | :::GsmFather::: | Cruiser Suite | 4 | 02-24-2006 17:56 |
what is the correct procedure to use 4-in-1 cable to unlock sharp phones with sonics | jesto80 | Sonics Box | 4 | 09-29-2005 04:02 |
