10-22-2008, 12:04 | #31 (permalink) | |
Junior Member Join Date: Apr 2005
Member: 136656 Status: Offline Thanks Meter: 1 | Quote:
here is result of update (appr. 1 houre waiting) | |
10-24-2008, 15:15 | #34 (permalink) | |
Junior Member Join Date: Oct 2006 Location: Mothercity
Member: 375139 Status: Offline Thanks Meter: 2 | Quote:
10-25-2008, 04:59 | #35 (permalink) | |
No Life Poster Join Date: May 1999 Location: Thailand Age: 50
Member: 125 Status: Offline Sonork: 100.100000 Thanks Meter: 1,305 | Quote:
10-25-2008, 19:59 | #36 (permalink) |
Member: 375139 Status: Offline Thanks Meter: 2 | Usage in pair with SHU box (HWK+SETool) and 7 ports USB hub (for flash disks and phones) only. These all things were pluged & unpluged many times and don't cause this panic. Today, I've remember that before this trouble were chipset drivers were reinstalled to new version, though with reWindows new drivers were installed too. Then I thought, may be drivers are conflicting? When system had found new hardware, it asked me that exisisting driver has newer version than JAF drivers software offers: changing them or not, same situation...so I decided to give the Windows an usb 2.0 driver from support (I prey, that earlier didn't use it), and, voila, even done unlock 6300 after bricked N73 by my trouble. So, this error don't disappeared (sometimes it is), but box work became much better. |
10-25-2008, 23:40 | #38 (permalink) |
Member: 375139 Status: Offline Thanks Meter: 2 | From this update my problem has begun, written upper (seems driver conflict). My post, you replyin', worked on 1.98.48 (!) BB5 unlock procedure which is better for me then highest, 'cause of continious sending code tries. N73 was bricked by 1.98.61, 10 unlock tries together, "p-key dongle not bla-bla-bla" and me together, now software can't restore lock data but it is another thread I think. P.S. I use 1.98.48 only for unlock, common flashing/service options usually going with newest software. Last edited by Doul; 10-25-2008 at 23:46. |
10-26-2008, 21:55 | #39 (permalink) |
No Life Poster Join Date: Feb 2006 Location: URL - UnlockRepairLandia Age: 41
Member: 236218 Status: Offline Thanks Meter: 35 | JAF version 1.98.59 Detected PKEY: xxx Card life counter: 78.16% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.0.2.0 Starting Card UPDATE... 22:52:43.796 [ERROR] Could not connect to server. Please make sure you have internet connection and firewall is not blocking access.Starting Card UPDATE... 22:53:04.906 [ERROR] Could not connect to server. Please make sure you have internet connection and firewall is not blocking access. tested with ver 58, 59 and 61 - NOT WORKING |
10-26-2008, 23:01 | #40 (permalink) | |
Thanks! | |
Pls help me!! [ERROR] Could not find server | akogaion | J.A.F. By Jafsupport.com | 18 | 01-24-2009 12:38 |
K750 error - COULD NOT FIND EXTERNAL RAM | mahcin | Cruiser Suite | 1 | 03-20-2008 15:45 |
UID BOX ....Error, could not connect provided server! | Bao Tran | UID - Box | 2 | 09-19-2007 22:43 |
10:55:17.734 [ERROR] Could not find server | MGT SOFTWARE | JAF Xtras | 1 | 02-12-2007 08:27 |
