12-01-2007, 18:22 | #16 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
I have just tried to downgrade. Nothing has been solved Code: ------ Operation: UNLOCK Date: 01-12-2007 Time: 18:10:01 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_05.01_21-05-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_05.01_21-05-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Code: ------ Operation: UNLOCK Date: 01-12-2007 Time: 19:03:27 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_04.91_03-04-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_04.91_03-04-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_04.91_03-04-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. | |
12-05-2007, 11:25 | #17 (permalink) |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | I flashed it with RM-274 (3109) but it didn't help me! Code: ------ Operation: UNLOCK Date: 05-12-2007 Time: 12:18:35 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-274 Version: V_05.30_16-05-07_RM-274_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-274_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_05.30_16-05-07_RM-274_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-274_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_05.30_16-05-07_RM-274_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
12-26-2007, 08:00 | #18 (permalink) |
Major Poster Join Date: Jun 2004 Age: 35
Member: 68631 Status: Offline Thanks Meter: 5 | 3110 unable to unlocking Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_04.91_03-04-07_RM-237_(c)_Nokia. IMEI: 358672011615469 SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_358672011615469_Locked_Keycnt_1_Fbuscnt_10__V_ 04.91_03-04-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... ERROR: Cannot find any usable backup file |
12-26-2007, 13:54 | #19 (permalink) |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Another 3110c unlocked ok. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 356975017611008 SP LOCK status: Config Key: 2600300000000000 Block 1: CLOSED Type 5 Data: 26003F Block 2: CLOSED Type 5 Data: 26003F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_356975017611008_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2600300000000000 Block 1: OPEN Type 5 Data: 26003F Block 2: OPEN Type 5 Data: 26003F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull flash M39L0R807 0ULZD5F |
01-19-2008, 13:06 | #20 (permalink) |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Still can't unlock 3110c [code] ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:00:28 ------- ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:00:28 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:00:37 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11200001 ERROR: 30020033 ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:00:54 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11200001 ERROR: 30020033 ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:01:20 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:02:34 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:02:48 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:03:27 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:03:36 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:27:17 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:27:42 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:27:50 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:28:59 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:29:08 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:29:55 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:30:24 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:30:30 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: 11140001 ERROR: Connection with phone was lost! ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:31:48 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:31:54 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:32:34 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:33:15 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:33:25 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:33:36 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:33:41 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:34:40 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 4 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:34:56 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: 11140001 ERROR: Connection with phone was lost! ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:38:09 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:38:24 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:39:05 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:39:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:40:35 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:40:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:41:32 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:42:33 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:43:19 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:46:02 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:46:41 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_3_Fbuscnt_10__V_ 05.50_14-08-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:47:58 ------- Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:48:06 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:48:15 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:48:28 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:49:45 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:49:57 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:50:05 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 4 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 19-01-2008 Time: 13:51:25 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 4 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:51:37 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 19-01-2008 Time: 13:53:04 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 19-01-2008 Time: 13:53:10 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.50_14-08-07_RM-237_(c)_Nokia. IMEI: 355523010142414 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_6__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-237_355523010142414_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-237_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP cod |
02-24-2008, 23:07 | #22 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | This was interesting Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-274 Version: V_05.30_16-05-07_RM-274_(c)_Nokia. ****: 35643401427***x SP LOCK status: Config Key: 2160100000000000 Block 1: CLOSED Type 5 Data: 21601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-274_35643401427***x_Locked_Keycnt_0_Fbuscnt_0__V_0 5.30_16-05-07_RM-274_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7#Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2160100000000000 Block 1: OPEN Type 5 Data: 21601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull Only with metod 2 |
3110c, can't start up normally, flashing ok | dinoadropy | HWK | 5 | 01-31-2010 15:04 |
help on 3110c can't be flashed with hwk ?? | abdouunlok | HWK | 4 | 12-25-2008 04:07 |
help on 3110c can't be flashed with hwk ?? | abdouunlok | HWK | 6 | 12-15-2008 20:43 |
3110c can't unlock with MTPRO strange | Sakura | MT-BOX | 10 | 12-11-2007 15:58 |
