11-14-2008, 01:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | 3110c unlocking problem plz help me i tried to unlock 3110c with bb5box..but i cnt do it for some reasons. i tried putting ground to diferent locations but still i cant do it. i also tried to downgrade the phone from V5.50 to V5.01. but still didnt help me. i tried abwt 2 ground on PCB but still same thing...can any help me plz thanks here is the log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-237 Version: V_05.01_21-05-07_RM-237_(c)_Nokia. IMEI: 356815028300086 SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-237_356815028300086_Locked_Keycnt_0_Fbuscnt_0__V_0 5.01_21-05-07_RM-237_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. i tried it many times but still same thing even i tried with external power as well but no chance to get it unlock... |
11-14-2008, 02:12 | #2 (permalink) |
Major Poster Join Date: Jan 2008
Member: 673993 Status: Offline Thanks Meter: 3 | Response Byte 55: is No communication with handset. Response byte 08: is either bad TP or bad earth. Move earth closer to TP (on a sheild or exposed tracks on board.) Try process again and post results. |
3110c flash problem plz help me | sanjay rana | Nokia Hardware & Hardware Repair | 8 | 03-17-2010 04:49 |
3110c flashing problem plz helpe | mogrem.soft | HWK | 16 | 12-27-2009 13:03 |
3110c flashing problem plz helpe | mogrem.soft | Nokia Base Band 5 ( BB-5 ) | 14 | 12-27-2009 10:21 |
3110c flashing problem...plz help me | manishber | Nokia Base Band 5 ( BB-5 ) | 9 | 07-17-2009 00:15 |
3110c Keypad Jumper. Plz Help Me | abdurrahimsagar | Nokia Hardware & Hardware Repair | 6 | 01-18-2009 09:01 |
