Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-30-2007, 23:17   #1 (permalink)
Member: 481700
Thanks Meter: 14
can't unlock 6280 spansion chip 3.81
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-78
Version: V_03.81_09-05-06_RM-78_(c)_Nokia
IMEI: 352265010xxxxxx
SP LOCK status:
Config Key: 2680600000000000
Block 1: CLOSED Type 5 Data: 26806F
Keyboard wrong codes counter: 1 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-78_352265010xxxxxx_Locked_Keycnt_1_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-78_35226501xxxxxxx_Locked_Keycnt_1_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin
Writting PM Field 308 Subfield 1 with length 4096 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 02
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
Unlock fail. Please try again.
Old 12-03-2007, 12:34   #2 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
need profiesional hands and quick also
but the data cable firist (with button) then but clk so fast as u can
tested alot alot alot
regards melmel
Old 12-03-2007, 12:41   #3 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
just connect the right tp and the ground must near in cpu
br
Old 12-03-2007, 12:53   #4 (permalink)
tuhingr's Avatar
Member: 152752
Sonork: 100.1581661
Thanks Meter: 182
and trun off ur dc supply near bb5box and PC.
unlock 6280 (span) v 3.81 hawks007 J.A.F. V-SPEC 2 06-10-2008 21:08
0.0.3.0 cant Unlock 6300 Spansion Chip!!!! samusprime BB5BOX 28 03-29-2008 23:04
cant unlock 6280 SPANSION FLASH CHIP 99026 BB5 Box by D.K. 5 03-04-2008 00:02
NOKIA 6280 Spansion Chip Unlocked Successfully .::BHATTI::. UID - Box 20 12-03-2007 11:59
6280 Spansion Chips Unlocked ehd0429 BB5BOX 0 10-30-2007 14:39
Page generated in 0.16662 seconds with 9 queries
