02-27-2008, 01:55 | #32 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Solved... Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: V__3.06.33.09.11_23-04-07_RM-88_(c)_Nokia. IMEI: 357***************x SP LOCK status: Config Key: 7321010000000000 Block 1: CLOSED Type 5 Data: 732101 Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-88_35*********************x_Locked_Keycnt_2_Fbuscn t_0__V__3.06.33.09.11_23-04-07_RM-88_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-88_357******************x_Locked_Keycnt_2_Fbuscnt_ 0__V__3.06.33.09.11_23-04-07_RM-88_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7321010000000000 Block 1: CLOSED Type 5 Data: 732101 Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7321010000000000 Block 1: OPEN Type 5 Data: 732101 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull Reflashed to Version: V__3.06.33.09.11_23-04-07_RM-88 firmware....... and works at first try....XDDD wbr |
BlackBerry from Cingular code error | y3kt | A1-Services.org | 1 | 09-05-2008 19:01 |
Unlock E62-1 Cingular | Advance-UFS | AdvanceUFS | 2 | 03-08-2008 09:12 |
Motorola Razr V3 from cingular won't unlock.. | luisfer99 | Motorola P2k | 15 | 09-20-2007 06:53 |
help..how to unlock se t61z from cingular | salemcell | Phone Unlocking Codes & Maps | 1 | 04-14-2004 23:41 |
