Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 12-11-2007, 03:37   #1 (permalink)
Member: 305311
Thanks Meter: 227
Exclamation again faild to unlock 5200 rm174 v.5.00
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.00_27-04-07_RM-174_(c)_Nokia.
IMEI: 357672014988765
SP LOCK status:
Config Key: 2340000100000000
Block 1: CLOSED Type 5 Data: 23430F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_xxxxxxxxxxxxxxxx5_Locked_Keycnt_0_Fbuscnt_10__ V_05.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-174_xxxxxxxxxxxxxx5_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Unlock fail. Please try again.
Old 12-11-2007, 04:23   #2 (permalink)
masterunlocking's Avatar
Member: 488825
Thanks Meter: 365
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Just downgrade to V4.71 using jaf or any other flasher and then unlock, should work, i had same problem and did that, now phone unlocked.
Old 12-11-2007, 09:02   #3 (permalink)
Member: 20953
Thanks Meter: 94
don't connect ground!
Old 12-11-2007, 09:04   #4 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
Type: RM-174
Version: V_03.92_13-10-06_RM-174_(c)_Nokia.
IMEI: 355537011543388
SP LOCK status:
Config Key: 2080100000000000
Block 1: CLOSED Type 5 Data: 20801F
Reset phone ...
Autobackup file:
RM-174_355537011543388_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin
already exist
Finded backup file: RM-174_355537011543388_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
with atd
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
still problem i have at least 3setts of test point
Old 12-11-2007, 10:11   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
I am sure now that there are Bugs on BB5box Hardware
not software
when u tried 50 times it will unlock at 1 time .
even cables are OK
Softawre is OK .
I personally think it a hardware Bug
Old 12-11-2007, 13:25   #6 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
with atd
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Type: RM-174
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
no proplem with 5200 -6300
just update box firmware and sure that ur bower supply of ur computer is good and fast do unlock you will fase no proplem
regard's melmel
sonork: melmle1989
Old 12-11-2007, 13:49   #7 (permalink)
Member: 488825
Thanks Meter: 365
I told you downgrade to V4.71 and it should work that way, i had same problem with v5.0 and v3.92, not working for me, allways getting 08 error. Try that way and post results.
3120c faild to unlock ronkiton MT-BOX 11 03-10-2009 04:37
5200 rm174 version 5.53.. any1 have it?? urgent?? khem Nokia Base Band 5 ( BB-5 ) 0 07-19-2008 11:06
problem unlocking 5300 sw version 5.00 preshaust J.A.F. Plus 25 12-23-2007 11:45
5200 SW Version 5.00 Unlock Solution !!! mughalG BB5BOX 58 12-20-2007 15:48
HELP TO UNLOCK 5200 -V5.50 -ATD cant unlock in ver 5 CHAPRAN BB5BOX 3 12-11-2007 14:09
Page generated in 0.29782 seconds with 9 queries
